Question about Faberware 350 Watts FSM126E Stand Mixer
Parts list I have this mixer and the beaters will not turn so I disassembled it and discovered that the gears have melted because they are plastic where can I get new gears from?
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The mixer will not start. Power gets to the unit and the blade does turn manually.
Hi - I assume you mean to say that the motor turns on, runs in all speeds but no power is being transferred to the planetary head and beaters?
If this was preceeded by some intermittent run conditions like occasionally skipping beaters and some louder than normal or different run noise then it's likely that the nylon Worm Gear has lost teeth and is no longer making contact with the motor gear. It is part of an assembly which is directly coupled to the motor. Disassembly is required to get at this part and some mechanical skill to replace it. If the mixer's a few years old and/or gets a lot of use, the gear grease should be replaced too. For the gears and other parts, including the grease - check out http://www.goodmans.net/get_dept_933.htm They seem to have just about every part needed and fair pricing. Appliance Parts Pros is another source of parts and diagrams. Warning - mixer disassembly is a medium complexity task and could ruin your day...
DZII
Jan 02, 2010 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid ksm150ps standing mixer's top seems to tilt down too low and bounces up and down when mixing
Hi DENISE, by the symptoms you describe it appears that it’s time to adjust your mixer’s Beater to Bowl Clearance adjustment screw, or head locking mechanism (or a component) of it is worn or loosened due to normal wear and tear and needs to be readjusted (or repaired) to keep your mixer head stationery and level.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
If the above doesn’t correct your problem, then you need to look at the Link & Lever Latch assembly. If you don’t have your parts list manual, select the file KSM150PSWH0.pdf (773.44 KB) listed under the Parts List Manual (61).
The manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to page5, titled: Base and Pedestal Unit. You’ll want to focus on Illus. #11, Link & Lever Latch assembly, and the related components, which locks the mixer head to the pedestal when you run the mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, and reassemble your mixer.
Finally, if you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Dec 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Faberware 350 Watts FSM126E Stand Mixer Logo
35 people viewed this question
Top Faberware Food Mixers Experts
eyecam
Are you a Faberware Food Mixer Expert? Answer questions, earn points and help others
