Question about Gateway NE56R31U Celeron Dual-Core B830 1.8GHz 4GB 320GB DVD RW
Using F2 at start up, I can't access BIOS on Gateway NE56R31u. Laptop powers on, CPU fan runs and HDD spins. No splash screen running Windows 8.0. Does motherboard Q5WVH LA-7912P Rev. 1.0 have solder
The laptop initially would boot to the Windows logon screen but would automatically shutdown in less than a minute. In safe mode, the laptop would stay on for a longer period of time, and I noticed the OS was compromised (no windows update feature, inability to complete a virus scan or perform an update through Microsoft's website, inability to refresh drive or restore drive to a previous restore point, etc). For normal boot, I would have to continuously turn the power on and off until it finally would boot up (still only for a short period of time). Ultimately, for no apparent reason, the HDD was wiped clean of all data. I reformatted the HDD and installed a previous version of Windows, but the laptop will not boot or provide access to BIOS settings. BTW, I removed and replaced the CMOS battery. Any help would be appreciated. (pxbrad1@hotmail.com)
  • 81 Answers
Try to boot from a linux live cd/dvd and erase/create new partitions
Posted on Jan 03, 2014
  • 794 Answers
Based upon what you describe, it sounds like you have a boot zero (sector) virus on your hard drive.
http://www.spotmau.com/products/package/bootsuite.html?SSAID=450974&src=shareasale
james klgr
  • 362 Answers
SOURCE: Gateway 450SX4 Notebook Overheating Problem
the best thing for you to do is purchase a cooling base its a platform with fans in it to blow air through the laptop all the time. these are greast for the newer faster machines they tend to run hot. you will also love the difference it makes in performance
Posted on Dec 11, 2008
  • 253 Answers
SOURCE: gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Posted on Jun 24, 2009
todd0708
  • 247 Answers
SOURCE: Gateway Initial Boot Up slow Before Windows
isnt there a quik boot option in the bios?,look at your system info in windows,rt.click my computer and hit properties,is your processor speed correct,and your ram memory all there.?should be a number divisible by 64,if its not and your missing 10 or 15 meg. one of your ram sticks is loose or failing,pop them out and reseat them,seems to help some of the time,hope this helps ,let me know more details
Posted on Sep 08, 2009
  • 10406 Answers
SOURCE: Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Posted on Sep 10, 2009
SOURCE: My Gateway ML6720 laptop will not boot, nor even
any news on this? I have the EXACT same problem.
Posted on Mar 15, 2010
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Asus r503u bios
Shut down your Asus laptop. Click "Start" then click the "Shut down" button. Power your computer back on. Wait for the ASUS splash screen. Press the "ALT" and "F2" keys on your keyboard as soon as you see the ASUS splash screen. Your computer will enter the BIOS.
Feb 14, 2013 | ASUS R503U-RH21, AMD E2-1800, Laptop, 4GB,...
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
I turn the laptop on but it immediately turns off within seconds
1. First step is to check if the laptop is overheating:
  • Does the bottom feel very hot to the touch
  • Is the CPU fan not spinning up
If it is hot to the touch and the CPU fan is not spinning up, this will cause the system to overheat and shutdown as a safety feature. In this case the fan would either need to be cleaned or replaced.
2. Failing hardware can also cause this (i.e. a failing motherboard, CPU, Battery, Power Cable, internal PSU, etc.):
  • Did you notice any system freezes or slow down prior to this happening
  • Have you noticed a sharp decline in battery life
Try disconnecting the battery and then only use the power supply cable to power up your laptop. If the problem still occurs, then reinsert the battery and remove the power cable and attempt to start up the laptop with only the battery inserted.
3. In some cases this can be caused by a malware (virus) infection. The infections that cause this can sometimes be remedied, but usually require expert assistance and the remediation process is very specific to that type of infection.
  • Does it get to the first splash screen (i.e. the BIOS splash screen)
If it doesn't get past (or even to) the BIOS splash screen (usually a Dell Logo) then that would point towards it being a over heating issue or Power issue.
Having said that, it's more likely a hardware issue (i.e. dead to dying Battery, failing Power cable, broken CPU fan, etc.) instead of a virus infection. Make sure to check the first two steps to get you closer to properly troubleshooting your issue.
Feb 01, 2011 | Dell Latitude D620 Notebook
Gateway computer - cannot boot up--
At boot up press F2 and enter BIOS. Here check if your HDD is recognized. If yes Ten your Windows is corrupted and needs to be reinstalled. How to install and save your data follow the link below:
Crashed Windows : No Problem
If the HDD is not being recognized then run Auto Detect to recognize the HDD. If it works fine, if not then the HDD may need a change.
Jan 25, 2010 | Computers & Internet
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Gateway M-6307 power dies on boot up (reaches widow screen dies)
Make sure that it must be charged. If you are sure, there might be a problem of overheating.
If you check, there is a CPU fan. Overheating might cause thie.
Use a vacuum to cool on the fan to make it spin manually, hmmm it actually started to work after that.
If not, let me know.
Thanks for using "Fixya".
Jun 18, 2009 | Gateway M6307 Notebook
Gateway 675 fan problem
Check the BIOS in the laptop. The CPU fan and unit fan is controlled by temp. U can set it for a lower temp. The Bios is accessed when U boot up... F2 usually, There should be a 5 to 15 second screen telling u what to press to get there.
Good luck
Mar 07, 2008 | Computers & Internet
Gateway NE56R31U Celeron Dual-Core B830 1.8GHz 4GB 320GB DVD RW Logo
215 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
