Question about Maytag Dryers
While drying a comforter, after I put it on for longer, it made a noise and stopped working
  • Maytag Master
  • 8,220 Answers
Probably blowed the small fuse near the heat source. Maytag dryers are known to get slipping blowers and a large comforter would cause overheat with an already bad blower and a partially clogged filter chute. What I would do is get the front off and remove the drum ,clean the the lint out of the machine and inspect for loose blower wheel. The fuse is usually mount right near the heater element and some are held to the heater chamber by the same screw that holds down the element.
I worked on one style of Maytag Machine and did a video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 03, 2014
I put a torsion key lift on my 98 silverado(new offset torsion keys cranked all the way up for around 2 inches of lift) wondering if there's anything I can do besides lowering it to ease out the ride. I've...
if you alter the standard ride height where standard travel shocks are installed , you have to alter the shocks to accommodate the difference in travel for the shocks
2" higher = 2 "longer shocks or 2"' lower =2 " shorter shocks next use a shorter bump stop for the arms so that the stop is not hit on the slightest bump
remember that the engineers design the car for maximum stability and ride comfort and when you decide that you are not happy and change it then stability , road handling and comfort all go out the window
Oct 19, 2017 | Cars & Trucks
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
My model wasnt in the available list; I have a 1967 VC Valiant, which broke down about 6 months ago and hasn't been run since. I have replaced the alternator, as I was told (by an auto electrician)that...
Love your choice of car!As far as the flooding goes take your air filter assembly off and while some one is cranking the car and you do the throttle you can see how much fuel is going into the engine.If too much you will smell and see a lot of fuel,it may be that that pump or associated fuel parts have dried out etc and no longer working.Put a little bit of fuel into the carburettor and see if it fires up.that will isolate the problem to being a fuel delivery issue and not electrical or ignition.Let me know how you go and if you need any other help
Oct 31, 2008 | Chrysler Voyager Cars & Trucks
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Water in VW Passat 1999. Car no longer works. What could be wrong
Does your passat have a moonroof? Mine does. The comfort control module under the drivers seat was shot. It pretty much controls everything. I havr dried it out twice now. Repair cost was 800.00 Would NEVER buy another volkswagen. Very poor design
Oct 15, 2008 | 1999 Volkswagen Passat
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
