Question about Freightliner 2005 BUSINESS CLASS M2 106
FAULT CODE SPN-393228 WHAT DOES THIS CODE MEAN
GETTING ACTIVE CODE SPN 393228 INTERMITTENT DATA
Fault code 1 Fail 31 Spn1569 2015 Cascadia Cummins engine
spn 1569 relates engine protection torque derate -condition exists.
critical fault codes related to engine operation are active
code 1 means urgent attention
A sort of limp mode setting that requires immediate attention by a cummins service center to prevent further damage to the engine
go google and type in--- cummins engines fault codes (or cummins engine fault code 1569) and there are pages of pdf downloads that list all the codes and what they stand for
Oct 07, 2015 | Cars & Trucks
What does the error code PO119 mean on my 2013 arctic cat 500 atv mean
From Repair Pal:
Auto Systems and Repair
Engine Coolant Temperature Circuit Intermittent Our emissions expert has put together the following information about the P0119 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
  • OBD II P0119
Fault Code Definition
  • Engine Coolant Temperature Circuit Intermittent
What does Mean?The Engine Coolant Temperature Sensor measures the rise and fall of the Engine Coolant Temperature. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, the cooling fans, and many components of the Emissions Control Systems. The Engine Coolant Temperature Sensor converts the coolant temperature into a voltage that is high when the engine is cold and low as the engine warms up.
Code P0119 indicates an intermittent voltage input from the Coolant Temperature Circuit to the PCM.
Sep 16, 2014 | Arctic Cat 2013 500 TRV Core
What mean this default code on volvo d13 SPN 3226 FMI13
faulty aftertreatment outlet, ....... knock sensor, and check coolant temp sensor,if it is faulty it will cause a rich condition that can throw misleading codes. knock sensors often fail and throw code when no other fault is present. good luck and happy motoreing!
Sep 13, 2014 | Cars & Trucks
Kenworth 2014 t800 with Paccar motor. Fault codes SPN:5109 and SPN :3217. Just wanted to know what they're for.
Spn codes are not very good indicators of what's going on.
This is a general protocol that all manufactures use and I don't find it reliable. If there is an engine light on with a wrench in it. Get to the dealer. If there is no wrench it's not as urgent.
Aug 02, 2014 | Cars & Trucks
Generac fault code 1600
our Iveco generator 400 kva Shaw us fault code (spn 65579)
Jun 01, 2014 | Generac Guardian Electrical Supplies
Intermittent stumble at idle
Cylinder misfires at idle that are not very noticeable under load or higher speeds are usually caused by vacuum leaks (most common) or low compression on one or more cylinders. Fuel control system malfunctions can also cause this, but it will take a trained technician that can analyze the computer input and output data to determine the actual cause if this is the case. Please note that when I say "analyze data" I DO NOT mean simply hooking up a generic OBD code reader and pulling fault codes.
May 04, 2012 | 2002 Chevrolet TrailBlazer
Have a 1997 honda accord ex with a trouble code P1253, any ideas what that could mean?
hello ragdollsophi,
I am assuming you have a 4 cylinder engine. P1253 usually indicates a problem with the VTEC solenoid, connector, or wiring. I would recommend clearing the fault. After getting the fault cleared, in a safe area, accelerate the car in low gear to at least 4000rpm for 2-3 seconds. If the fault does not come back, then repeat the drive test a few more times. Assuming the fault does not return, the problem is intermittent.
Jun 25, 2011 | Honda Accord Cars & Trucks
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Feb 03, 2010 | 2002 Audi A4
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
Freightliner 2005 BUSINESS CLASS M2 106 Logo
125 people viewed this question
Top Freightliner Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Freightliner Office Equipment and Supply Expert? Answer questions, earn points and help others
