Question about Sylvania CL772B 17" Flat Panel LCD Monitor
No picture on monitor
Green light comes on and flashes but no display
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
My monitor green light keeps flashing. I cannot get a stead display.
Flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the viewsonic logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Dec 23, 2009 | ViewSonic VX924 19" LCD Monitor
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Sylvania CL772B 17" Flat Panel LCD Monitor Logo
67 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
