Question about Frigidaire Washing Machines
How to use the washer
Where do I put the detergent
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
Do you put detergent in the frigidaire affinity front loader clean washer cycle?
Good Afternoon Jodi,
I understand that you are wondering if you put detergent in your Frigidaire Affinity washer for the clean cycle. You do not put detergent in. You will want to take the detergent cup out and put a cup of bleach in there when you run the clean cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Where to put the powder detergent in the washer? how come did not dissolved?
Chances are that the washer is a front load. If it is it requires liquid detergent. If you want to use powder put it in with the clothes and not in the top detergent well.
Hope that clears things up.
ash
Vote please.
Sep 22, 2010 | GE WSXH208A Front Load Washer
REGULAR DETERGENT ON HE PLUS
Regular detergent causes the washer to make too much suds. Use HE detergent unless you want to fry your washer. You can use regular detergent as long as you use a small amount.
Jul 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Jul 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
What to use in my washer?
If your washer is rated for HE detergent, then you're supposed to use HE detergent. The reason being is that HE detergent is concentrated and specifically made for washing machines that use LESS water than conventional washers. Regular detergents are formulated for machines that use about 35 gallons of water for a full wash tub. If you use that same soap in a washer that only uses 5 to 7 gallons of water, you are in affect putting a higher concentration of soap in your new washer. Originally, manufacturers of HE machines stated that you could use regular detergents as long as you cut back on the amount. They later retracted that statement, because regular detergents were damaging the HE washers. You should review your warranty closely. Most newer models now have a disclaimer that states if you use the wrong detergent in your new washer, the warranty becomes null and void. I hope this answers any questions you may have.
Feb 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
