Phillips TV smells like body odor - Televison & Video
Why do some Bully stick smell?
Nothing to do with car issues.
Aug 18, 2017 | Cars & Trucks
We have three samsung plasma tv's that all smell like body odor, we have had them for about 5 years so this is not a " new from the box "kind of smell
Do the TVs still work ok?
it could be that they have just become dusty. take the back off them and give them a good dusting out. try not to use brushes and rather use compressed air. you can get this from most computer shops.
Jun 08, 2014 | LG 50PX5D 50 in. Plasma HDTV
Is there a difference between a deodorant and an antiperspirant?
Yes there is, while deodorant only help to prevent odor antiperspirant help prevent both odor and sweat. Antiperspirants are also good as deodorants because the active ingredients that are antibacterial.
Jan 10, 2013 | Health & Beauty
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
I have a 30,000 btu ventless mr heater for two months it has run with absolutely no smell,the other day I did some wood staining, now the heater has a strong co2 smell is their any way to clean the heater...
Sure is. Never operate a vent-free gas appliance (not even the pilot light) while painting, staining, cleaning carpets, etc. It picks up the odors and will not burn the odor off, because the odor doesn't get in the heater, it just makes the odor worse. You will need to turn the heater off and not use it, until ALL of the odor from the staining have completely dissipated . It may take a week or more, even though you may not be able to smell the odor from the stain, the warm moist air from the heater will activate it again. If you get a warm day soon, open a window or two and let the fresh air in. That will help dissipate the odor. But, allow a week minimum, before trying to use the heater again.
Oh, by he way, that wasn't co2 you were smelling. co2 is dry ice. It has no odor. Just like co (Carbon Monoxide) it has no odor. You were smelling the fumes from the stain. Just 50 times worse.
Good luck to ya,
Rich
Mar 02, 2011 | AOC Heating & Cooling
What is different between Deo & Perfume?
Deodorants (abbreivated as DEO) are substances applied to the body to eliminate body odor caused by the bacterial breakdown of perspiration. A subgroup of deodorants, antiperspirants, prevent odor and reduce sweat produced by parts of the body. Antiperspirants are typically applied to the underarms, while deodorants may also be used on feet and other areas in the form of body sprays.
Perfume is a mixture of fragrant essential oils and aroma compounds, fixatives, and solvents used to give the human body, animals, objects, and living spaces a pleasant scent.
Nov 23, 2010 | Health & Beauty
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
We have a Hotpoint washer model VBSR2080WOWW purchased 2001. Problem is that clothes often don't smell fresh at end of cycle. There is a musty or mildewy odor or sometimes they have body odor. Problem is...
you have too much body fat built up in the hoses and main barrel what you need to do is run it with pure hot water and put a dish washer cleaner fluid in the wash this will destroy all residue that has built up in your washer that is rotting as it sits.
good luck
Jul 01, 2010 | Washing Machines
Strong smell coming from back of unit
hmm, usually when i go to a call like that i find a remainding body of a mouse or rat, they try to make it to the pan underneath for water and get chopped, other than i would clean EVERYTHING....
Jun 23, 2009 | Whirlpool Refrigerators
Chemical odor...
from where does the smell come?
inside the unit or from the body?
does the smell spread to food items?
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
