Question about Garden
My Snapper S31SNG will not start after replacing carb.
I've replaced the purge bulb and fuel lines.  Too many neighbor's hands have gotten me totally confuse on it now.  HELP!!
  • 3 more comments
  • wadamarine May 22, 2009
    It will start most times the starter cord is pulled and runs briefly about 20-30 seconds in half choke.  When opening the choke fully, the unit stalls out.  Also, where/how should the little plastic piece on the fuel be placed in the fuel tank?
    There must be a bigger issue here.  I'm still having difficulty with it running beyond the half choke position.  Thanks for the assistance.
  • wadamarine May 25, 2009
    I just purchased this carburetor in hopes it would fix the problem but it didn't.  I figure the issue has to be more severe.
    I purchased it brand new.  I know that is not necessarily saying its a good carburetor just because it is new.  I've purchased new items in the past that were defective.
  • Jim Parker
    Jim Parker May 11, 2010
    When was the last time it started and how did it react at that time?
  • 1,041 Answers
A short fuel line leading from the primer bulb should be placed just inside the tank. This line may be larger than the other fuel line depending on your trimmer, so make sure that you have the correct sizes. The small plastic piece goes at the end of the fuel line to prevent it from pulling out of the tank. It also serves as a overflow. Cut this line a little longer than you need it until you get it in the correct position. (Hint: You may want to taper the end of the lines before putting them in the holes, it makes it much easier to feed them into the hole, then square them up after they are in.) The other line goes to the bottom of your tank with a small filter at the end.
Posted on May 22, 2009
  • 2 more comments
  • Jim Parker
    Jim Parker May 24, 2009
    You have a carburetor problem. You need to take your carb. apart and clean it. Use a DenTech brush, (used for teeth cleaning), to clean the small ports. You may also need to purchase a carb. kit for your Snapper and replace the gaskets and needle valve. Make sure to clean the small screen in carb. It can get clogged very easy. If you purchase a carb. kit, the screen should come with it. Clean the carb. with a can of carburetor cleaner. You may as well replace the air filter as well because you could complete this job only to have to tear it all back down again because of a dry rotted filter. Old filter pieces can come off, and get sucked off into the carb. Let me know how you do. It sounds difficult, but it really isn't. It should only take about an hour.
  • Jim Parker
    Jim Parker May 25, 2009
    Did you purchase a new carburetor or a used carb. If it's used it may have the same issues as yours.
  • Jim Parker
    Jim Parker May 26, 2009
    There are only a couple of things that I can think of at this point. (1.)The filter that is attached to your fuel line in the gas tank is clogged and won't take in any fuel; (2.) The gas cap is clogged, causing the air supply to be cut off to carburetor. The thing that tells me that this is not your problem is if your gas cap is clogged, the trimmer should run for approximately 10 minutes before shutting off. The way to tell if this is your problem is if when the gas cap is removed, you here a suction sound from the gas tank. Or (3.) The fuel line leading to the carb. is to large. It should be replaced with the same diameter line. I'm leaning toward (1.)Hope this helps.
    Jim
  • Jim Parker
    Jim Parker May 27, 2009
    Thanks for your rating "wadamarine. AND THANK YOU FOR YOUR SERVICE TO OUR COUNTRY!! If you should ever have any questions on drywall finishing, or know someone who does, put your questions to "Tools-Building & Power-Hand Tools.
    Jim
Pe200 echo edger i have replaced the carburetor, fuel lines primer ball it runs for 30 seconds to a minute then shuts off acting like its starving for gas
Have you connected the fuel lines up correctly to the carb and purge bulb? just remember the bulb pulls fuel from the carb, into the bulb and dumps back to the fuel tank, it is a purge not a primer.
Mar 05, 2018 | Echo Garden
Diagram fuel lines tank primer carbutor poulan pro weedeater
I have no diagram but here are the instructions on how it goes.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Jul 10, 2010 | Craftsman Garden
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Jul 09, 2010 | Troy Garden
Replace fuel lines,craftsman weedwacker, 358.798520 . Fuel lines disintegrated in gas tank. Three parts left in tank, fuel filter and two small plastic hose connecting items.How are these parts related to...
Fuel filter in tank with line going directly to the fuel pump side of the carburetor This is the end of the carb with a solid cover. . This line should have length in it inside the tank where it can flop around and stay on the bottom to collect fuel. The other line in the tank should have one of the little connectors on it and can be right up to where the hole in the tank is to hold it there.. This line should connect to purge/primer bulb on the longer outlet nipple. Another fuel line should run from the metering chamber side of the carb (the end with the hole in the cover) to the purge/primer bulb with the shorter outlet nipple.
The purge bulb "pulls" fresh fuel out of the tank via a vacuum created after depressing the bulb and the fresh fuel flows completely thru the carb and any air or old fuel ahead of it are drawn to the purge bulb which then "pushes" this mixture back to the fuel tank.
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
Not getting fuel replaced primer and hoses and not
It's easy to mess this up as I've done it in the past. If the unit has an external purge bulb, the fuel line from the fuel tank that has the fuel filter on it goes directly to the carburetor...near the part of the carb that holds the fuel pump and has the grooved cover (where an inbuilt purge bulb would be). The other line coming out of the fuel tank goes to the purge bulb. The side of the carburetor that has the diaphragm and metering lever cover has the line going to the purge bulb. Remember, this is not really a primer...the purge bulb pulls air and old fuel out of the carb and when it does this, fresh fuel flows into it...and then the bulb pushes that air and old fuel back into the fuel tank. Hope this helps.
Jun 13, 2010 | Craftsman 25cc Gas Line Trimmer
Need help reconnecting fuel lines
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Sep 01, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Have a snapper snap n' go trimmer s31sng - One of the fuel lines or more were cracked and It quit running - replaced all fuel lines but don't think I reconnected them correctly. Do you have a diagram of...
I am not really sure how many lines you replaced. But the fuel line layout on most types of trimmers, weed wackers and lawn mowers are pretty straight forward. There is usually a line inside the gas tank for connecting the fuel strainer\filter. Then a line from the bottom of the tank to the carburetor. This line may also have a fuel filter located on it. On more complicated equipment you may find a breather line that loops back to the carburetor.
Below are a couple of links that might be helpful. The first three are diagrams of a similar 31cc Snapper trimmer and links to other Snapper trimmers. The fourth is to the users manual for your trimmer.
Hope this helps.
http://www.partstree.com/parts/?lc=snapper&mn=311+31cc+Straight+Shaft+Trimmer+Series+1&dn=6600
http://www.partstree.com/parts/?lc=snapper&mn=310+31cc+Straight+Shaft+Trimmer+Series+0&dn=6597
http://www.partstree.com/parts/?lc=snapper&mh=19
http://dl.owneriq.net/a/a3fbde0d-dc76-4963-935f-821589699385.pdf
Sep 01, 2009 | Troy Garden
Need carb screw settings
Hi try setting the screws at 1&1/2 turns out from the closed position and go from there.
Aug 30, 2009 | Garden
Garden Logo
1,119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
