Question about Pioneer DEH-1500 CD Player
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS? which wires are what thank's.
    President:
  • 547 Answers
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
Posted on Oct 02, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1983
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Illumination: n/a
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/Black
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1388
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
I would like to install this into my 2002 Ford Explorer
You need the Metra 70-1771 Receiver Wiring Harness. You can enter this wiring harness under google search then select the web shopping option. Or you can copy and paste this link:
http://www.crutchfield.com/p_120701771/Metra-70-1771-Receiver-Wiring-Harness.html?showAll=N&search=Metra_70-1771_Receiver_Wiring_Harness&skipvs=T
IF you google it under shopping remember you will find same item for lower cost. Your choice
most people dont know this but the brake cable from the DVD player usually its pink, you tie it together with the vehicles black ground cable. This will allow you to use the DVD player while driving. (remember though its considered illegal in CA. I only let you know for informational purposes. Hope it helped
Carlos Q.
Mar 10, 2015 | Pioneer AVH-P5200DVD 7 in. Car DVD Player
How do i replace my stock radio for a after market radio in a 1995 lexus sc400
There are several steps:
1. Take out the center cup-holder (it pops out with a little tug upward). unscrew the 2 screws.
2. On the shifter (lower part) there is a cover that covers 2 screws, unscrew and remove the shifter knob.
3.Take a pick tool and lift the shifter bezel console (black) it also pops up.. there are 3 or 4 connecters (disconnect with a small flat head screwdriver)
4. Once the shift cover is removed, there are several screws and tabs holding the bezel trim down unscrew the screws and lift bezel trim up,
5. Disconnect the ash-tray (blue connector)
6. Disconnect the hazard signal control , volume control connector and the climate control connector.( On the left side)
7. There are 4 screws holding the the radio and climate unit cage to the dash frame. (unscrew)
8. Now it gets a little tight, pull the unit towards you slightly and disconnect to connectors for the climate control unit (on top) and the factroy radio (on the bottom).
9. Next remove the radio and climate control unit from the cage(screws on the sides).
10. Next you will need a new cage: Metra 95-8157B Double DIN Installation Kit for 1992-2000 Lexus SC300 and SC400 (Black)
by Metra Link: http://amzn.com/B001TJG7SA
11. You will need the following harness: Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin by Metra
Link: http://amzn.com/B0002BEUBW and/or Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker by Metra Link: http://amzn.com/B0002BEQJ8
12. Match the wires according to the metra kit and new radio instructions.
13. Next follow instructions in reverse for re-stall. GL.
Feb 09, 2014 | 1995 Lexus Sc 400
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
CAN U PLEASE TELL ME WHAT ALL WIREING HARNESSES I WILL NEED TO INSTALL THIS IN A 2007 HONDA ACCORD
You will require a wiring harness (different numbers for different manufacturers)
Metra, American international, Scoche, and more make them.
I carry metra, so the metra part numbers are as follows...
Wire Harness: 70-1721
A mounting kit is also required... 99-7862
It may be in your best interest to visit your local car audio shop - as there are several trim levels and radios for your vehicle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 27, 2009 | Pioneer AVX-P7300DVD
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
Pioneer DEH-1500 CD Player Logo
906 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
