Question about Ovens
Oven fuse keeps blowing
Plug fuse keeps blowing
2 Suggested Answers
skrbin
  • 121 Answers
SOURCE: fuses keep blowing on panel, is it possibly a problem with the oven shorting?
must have 16 or 20 amps fuses
Posted on Feb 16, 2009
My Neff oven keeps blowing bulbs, immediately a new bulb is fitted it blows like a fuse.
Maybe your First bulb in the oven is a 220 volt bulb not a common 110 bulb? Good luck.. BCB...
Oct 23, 2016 | Neff Ovens
Why does it blow the fuses
Possible fault on the door switch
Nov 14, 2015 | Ovens
The control panel went out the oven fan still blows but the oven does not heat up nor do the panel light up
if this is a new oven/stove its possible there is a fuse that has went out. pull away from wall (unplug) start looking everywhere you can for a fuse, keep a magnet handy to keep your screws together, or just place in a bowl. also a flashlight is handy. try to hunt down the issue yourself if you cant afford to have it serviced. I had my refrigerator stop cooling , fan was blowing just no cold air, I pulled it out and looked inside the motor area and noticed a wire had been chewed in half by a mouse, unplugged it ,spliced the wires back together, black tape, plugged back in and shazam ! fixed..then the mouse hunt began!! good luck
Sep 27, 2013 | Kenmore 42161 / 42169 Electric Single Oven
NO POWER IS GETTING TO THE MICROWAVE NO MATTER WHERE I PLUG IT IN
the internal fuse inside the microwave has blown.JUST REPLACING THE FUSE PROBABLY WONT FIX IT the fuse usually blows when one or more of the door switches is bad so fuse and door switches would be needed
if ya replace the fuse and it blows again right away it defiently is going to be a door switch that is causing it to blow
Aug 25, 2011 | Ovens
My Prestige PR1 S0 oven suddenly stopped working. I checked the socket it was plugged into. No power when other electrical item (radio) is plugged in. I plugged the oven into a gang socket which was...
It sounds as if the oven element short circuited and tripped the oven circuit. You will need to reset the oven circuit breaker or rewire the fuse at the switchboard.
If the oven indicator light comes on when you turn the oven on you will need to replace the faulty oven element.
Feb 23, 2011 | Ovens
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Problem with electric oven
Either your fuse holder/breaker has a bad connection and has a voltage drop tripping your power  or  your heating element is shorting to it's outer jacket which is grounded.  Check your heating elements carefully for wear and disconnect that element and see if it trips still.
Nov 09, 2009 | Ovens
Microwave oven
The high voltage capacitor is probably shorted, (large, silver, oval shaped part). typically .98mfd to 1.02mfd
Jun 03, 2008 | Ovens
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
