Instructions to set clock - Audio Players & Recorders
Radio shack atomic clock 63-1438 instructions for setting clock functions
Download the user manual to your clock. It will have all details you want. To downlaod it, click here.
May 23, 2012 | Audio Players & Recorders
Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
Feb 21, 2010 | Audio Players & Recorders
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
Nov 10, 2009 | Pioneer DEH-1800 CD Player
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
I have a 'relaxed nature sounds lcd clock' with no instructions
Moderately difficult, but not impossible. ;) I picked up this clock @ second hand store with no instructions and was able to figure it out how to set it in about 15 minutes. I liked the calendar feature on the face and the LCD (as opposed to LED because I prefer my bedroom dark when I sleep).
When setting this clock, one of the keys is to pay attention to the the icons displayed on the face toward the lower left. Default "MODE" is time set. To set the time: Press "SET" followed by either "HOUR" or "MIN" while the display is flashing to increment the hours and the minutes to the correct time. As previously state, the default "MODE" is time set.
Pressing "MODE" one time accesses a secondary clock that you might use if you regularly travel to another time zone (new icon w/ 2 clocks appears). Setting the secondary clock uses the same method above.
Pressing "MODE" a second time accesses the first alarm setting (alarm clock icon starts flashing). Same method to set.
Pressing "MODE" a third time accesses the secondary alarm setting (second alarm clock icon appears and begins flashing). Same method to set.
Pressing "MODE" a fourth time accesses a timer (hourglass icon appears). Same method to set.
Pressing "MODE" a fifth time allows you to set the calendar (calendar year appears where the digital clock display was). Press "SET" to change the date: "HOUR" increments the month; "MIN" increments the day; "MODE" increments the year. Press "SET" again to exit.
Pressing "MODE" a sixth time returns to the default time set mode.
I hope this helps someone! God's blessings in Jesus Christ! ~Thomas
Mar 09, 2009 | Audio Players & Recorders
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
display appears on the display.
on or off.
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
1,209 people viewed this question
 Grubhead
Grubhead
