Question about Onkyo TX-SR504 Receiver
No remote how do you balance speakers - Onkyo TX-SR504 Receiver
Receiver channel volume not identical
Remote controls normally do not adjust stereo volume levels independently, and I will assume that the problem is present on ALL input settings (tuner, CD, etc.). Check "balance" control settings, speakers and speaker wires for possible problems. Balance control at 12:00? Inspecting speaker wires and speakers do not reveal problems? Have you swapped speakers to see if problem reverses? Try this "process of elimination" and hopefully you'll ID the problem.
Mar 23, 2015 | Yamaha Remote Control RXV496RDS...
How to change balance from left to right on speakers without remote
If it was working fine you may find the speaker cable damaged or disconnected from the amplifier.
Feb 16, 2015 | Bose Audio Players & Recorders
My lg tv's one speaker does not sound. Reply if it will solve with the remote of my lg.
its probably due to non balanced audio chek balance left right
if not that my be spaeker is detched from board
if not chek the dead speaker you must have continuity of 4 till 8 ohms if not change the loud speaker or ust use a home cineama audio its not that expensive
Feb 07, 2015 | LG Televison & Video
Pioneer audio video multichannel rec vsx-d810s the remote for this unit xxd3028 will not balance the speakers anymore. The batteris are new. What next
Have you tried balancing it from the Receiver?
What happens sometimes is that when the battery dies and you still use it,the buttons on the remote don't work.
The possible reason can be Dust,age of the unit can be another factor.
Pull remote's faceplate off and check the contacts, make sure there is not something obstructing or not allowing your faceplate to make proper contact.. You might need to pullout the screws using a screw driver.
The last option would be to buy a new remote.
Good Luck.
Mar 29, 2010 | Audio Players & Recorders
Remote doen't work properly
apart from the balance for the speak button on the remote, does other buttons on the remote work or is it all the functions on the remote that is not working any more?
This may be as a result of the faulty remote sensor or problem from the remote.
Which ever the case maybe, the remote need to be changed. But before you change the remote, if you have a friend the has the type of your remote, you can simply use it to test the remote first, before you get another remote.
Good luck.
Mar 29, 2010 | Pioneer Audio Players & Recorders
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Only one speaker is working
i also have the same problem. in the begining both of the speakers were working now it's only one. it's not the balance setting either, i think i either blew something, but both of the speakers work when i switched the wires.
Apr 15, 2008 | Nakamichi SoundSpace 8 System
Left speakers is louder than the right
maybe you have unfair inputs!? or your balance control is not working good... or you have defective parts! or maybe they change value like resistors and small capacitors, or u have leak driver transistors...
Sep 14, 2007 | Onkyo HT-S780 System
Onkyo TX-SR504 Receiver Logo
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
