Question about Neff Kitchen Ranges
How to replace the light fittings on a Neff cooker hood
ENR No. D8602NOGB
SOURCE: Neff cooker hood
the manual i have says that the charcoal filters inside need changing about every 6 months. take out the grease filters then you should be able to turn it and take them out. you may not have these if the extractor vents to the outside. the grease filters can be cleaned with a neutral detergent and then put back in. Make sure the electric is off before you do any of this. Hope this makes sense and helps!
Posted on Jul 17, 2008
manhandy
  • 146 Answers
SOURCE: light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
Posted on Jun 24, 2009
skyblue67
  • 71 Answers
SOURCE: instructions fr AEG competence 321 V-D
Hi you can download your manual here
http://www.manualshark.org/m/aeg-competence-321-v-d-instruction-manual-u03073-product-number-code-611251913-10108/
good luck
Posted on Jul 25, 2009
  • 32 Answers
SOURCE: My Neff D8900 cooker hood
Find the plug & chjange the 3 amp fuse
Posted on Sep 05, 2009
SOURCE: my neff cooker hood's fan and light suddenly don't
My light and Extractor have stopped working. Some1 advised Transformer may have gone. Is it beside Motor and how is it accessed to fix ? Thanks
Posted on Feb 02, 2010
USER GUIDES FOR NEFF OVENS
http://customerservice.neff.co.uk/product-advice
Use link, click on product advice, then click download manual, enter Enr (U1422s0GB) to access II (installation) IU (User manual)
Apr 12, 2013 | Neff Ovens
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Dec 08, 2012 | Neff Microwave Ovens
Shelf fitting slot broken off
Use the link http://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?x=0&y=0&Maktx=Neff+U1721&eshoptype=Aenter the FULL enr from the rating plate, don't just pick the nearest one if the enr is U1721N0GB/75 that's the model you need to check as parts from one model to another can vary. This will open a diagramatic breakdown of the oven and you can search for the relevant part (and buy if online direct from Neff). Couple of things to remember, make sure you have the right oven (ie top or bottom) and whether it is the front or rear holder as one is like a keyhole and the other is a keyhole on its side.As this is a build under unit, it does make changing the part a little easier (depending on which one is broken, hoping for your sake that it's not the back top oven one..Argggh!!) You will need to get the oven out and I find it easier if it's on it's side with the faulty holder at the top. The side panel needs to come off (or at least be loose if it's a front holder) as the holders are held in place by a retaining clip behind the cavity wall, or if it is a screw in type, the screws comes in from behind the cavity wall. I suggest you order and get the parts first and this will give you an idea what you're dealing with. Let me know how you go and post any comments or problems you have whilst doing the repair (anything I've forgot to add) as this will help anyone else looking for a solution to a similar problem.Ps. If you are sensitive to fibreglass, wear a pair of gloves.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
Hi I'm after a manual for NEFF 47442 cermaic hob please
This not the full ENr number required to get the instruction manual. Most NEFF hobs ENrs start with a T...Once you've found the number (should be on the base of the hob, which will mean removing drawers or possibly an oven to check) use the linkhttp://www.neffcustomerservice.co.uk/
go to the bottom left of the page and click on 'instruction manual download' this will open another page where you can enter the Enr and then get the user manual. either to store on the computer as a PDF file or to print off.Hope this helps.Roni
Sep 19, 2011 | Bosch Axxis WFL2090UC
How do I find the product code for my Neff dishwasher - it's built into the kitchen snd I need to buy a new wheel
You will find the Enr. and Fd. numbers on the top inside edge of the stainless in the centre near the door switch. It is etched into the stainless and it can be difficult to see in certain lights or the angle you look at it but it is there.
Hope this helps.
May 18, 2010 | Neff Dishwashers
My neff cooker hood's fan and light suddenly don't work-worked yesterday! please help
Jan 31, 2010 | Kitchen Ranges
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Kitchen Ranges Logo
73 people viewed this question
Top Neff Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Neff Kitchen Range Expert? Answer questions, earn points and help others
