Question about Izzo Swami 3000 Golf GPS Unit Kit
Won't hold battery charge
Weak battery
Honda 1998 cbr 900 rr battery won't hold charge
How old is battery everything has limit or alternator is weak.
Mar 17, 2013 | Honda CBR 900 RR Fireblade Motorcycles
Get my galaxy s to stop saying nonsupported battery
Drain the battery completely... Reset your phone. Often this fixes the problem but its likely your battery is weak and it won`t hold a charge for long. If it was not holding a charge well before this happened then i recommend just buying a new battery.
Oct 19, 2012 | Cell Phones
No power to anything except the anti-theft light is still blinking
check for weak battery should have 12.6 volts if not battery weak or dead, have battery charged and check out.if battery hold charge then more likely alternator not charging battery due to faulty voltage regulator.if battery weak cant be charged battery need replacing also clean or replace battery cables,clean corrossion from battery cables.
Sep 25, 2012 | 2006 Ford Freestar
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
When i stoped the car 24 hr the battery cant start the car
Check the fuses inside your power distribution box by the battery. I think there's a small (like 15 amps or less) fuse there for the alternator. If they are good,problem could be a weak alternator, loose belt, or poor connections at battery, or a battery that won't hold a charge.
Nov 09, 2011 | 2004 GMC Envoy
Bike won't start, starter soliniod clicks but starter won't roll over, it will hum and not turn over.
Those are the typical symptoms of a weak battery. Try either to charge the battery, try a jump start or replace the battery. Lights or horn working do not give an indication of the battery charge status.
Jun 13, 2011 | 1984 Yamaha XJ 400
I keep trying to get it to turn over but it keeps clicking and wont turn over. im thinking its the starter but it worked fine yesterday i had to jump it and it would turn over yesterday. i left it in the...
Most likely it is your battery. If it started when you jump started it then the battery was too weak, and it won't hold a charge, so when you park it overnigt it is not strong enough to start the bike. You may have loose or corroded cables and that can lead to a weak battery because it wasn't getting charged like it should. Unfortunatly when bike batteries get that weak they usually need replaced. Unlike a car battery they can't take the punishment of improper charging.
Apr 21, 2011 | 1981 Honda CX 500 A
Bike will not start, clicking noise, lights and indicators working ok - done this twice in a week but started ok, but now won;t start at all
If there is a clicking sound it is most likely the battery that is too weak to pull in the solenoid and hold it there while the starter drains the current. I think you need to either charge or replace the battery.
Apr 16, 2011 | 2007 Honda CBF 500
Battery not charging info light on
Hello and welcome to FixYa!
If the battery light is on, I strongly suggest that you have the battery charged. It can be an indication of a weak battery or a faulty alternator. If the battery light still on after charging then the problem will surely be on the alternator itself. If that's the case the alternator should be replaced to resolve the problem.
If the battery won't hold charge even on a new alternator then the problem will be on the battery itself. It surely is in the end of it's service life and replacement will be necessary.
You may try to reset it to by removing the positive battery connector, letting it sit for at least 5mins. then reconnect it again. This will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
Nov 27, 2010 | 1998 Cadillac Eldorado
Izzo Swami 3000 Golf GPS Unit Kit Logo
47 people viewed this question
Top Izzo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Izzo Optic Expert? Answer questions, earn points and help others
