Question about Datawatch Monarch Pro (FLP32MAINT6C)
Unexpected error occurred while building data view
Error occurs when trying to open monarch
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
Nokia C5-00 problem:camera not work(unexpected error occurred restart phone)
I have an error in my Nokia c5 camera that is not opening WebRepOverall ratingThis site has no rating(not enough votes)
May 20, 2012 | Nokia C5 Cell Phone
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
An unexpected I/o error has occurred 0xc00000e9
Always extract the hard drive from the machine and take the data off of the drive before you do ANYTHING close to a restore. You can get a USB attachment and plug the drive in to a good computer, then commence with diagnostics and repair of the laptop.
Oct 13, 2010 | Toshiba Satellite M45X-S331 Notebook
Nokia n72 camera unexpected error occurred.
unexpected error is occured when i was open camera ..
Jul 27, 2010 | Nokia N72 Cellular Phone
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Error 409 Memory full on Monarch 9850 printer
409 is a memory full error, so if you have reset the printer, then your memory should be "flushed". You may also have an incorrect flow control, so when you send too much data to the printer, you can get a 409.
Not knowing which your issue could be, try calling the company's support number 1-800-543-6650.
Mar 19, 2009 | Monarch 9850 TABLETOP PRINTER
Datawatch Monarch Pro (FLP32MAINT6C) Logo
526 people viewed this question
Top Datawatch Computers & Internet Experts
David Payne
David Payne
Are you a Datawatch Computer and Internet Expert? Answer questions, earn points and help others
