Manual for hotpoint wm31 washing machine - Washing Machines
5 Suggested Answers
  • 18 Answers
SOURCE: Hotpoint Aquarius WM31 Washing Machine
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Posted on Jan 01, 2009
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: replace belt on Hotpoint Aquarius WM31 washing
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Posted on Apr 05, 2010
Testimonial: "Job done, excellent advice."
  • 25 Answers
SOURCE: noisy bearings
ok, turn the nut at the back anti clockwise, i normally jam the pully into the cut outs in the drum, when you have taken off the nut hold the inner drum inside the outer drum and tap he pu;;y anti clockwise, not too hard or it will crack, remove pully, place nut flush with shaft on the thread and you will be ablt to tap the drum out without damaging the thread.
Posted on Apr 08, 2010
Testimonial: "excellent advice,job done"
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Hotpoint bwd 129 leaking from underneath (left side when looking at the machine) - i have checked the plugs at the back - all okay.
Hotpoint bwd 129 leaking from underneath This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 08, 2010 | Washing Machines
Noisy bearings
Apr 07, 2010 | Washing Machines
Replace belt on Hotpoint Aquarius WM31 washing
Hi.
Apr 05, 2010 | Hotpoint Washing Machines
Url for users manual for hotpoint WML520P ?
Go to>
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>
HOTPOINT USER MANUALS
In the search box enter in uppper case your model number without the P
You should now be able to download the instructions.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Hotpoint Washing Machines
No manual
HI. i have located the manual and you can access it via the link below. You can also print it out if needed.
CLICK HERE FOR THE HOTPOINT MANUAL.
Please rate and god bless:)
Apr 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
My washing machine..hotpoint bwm12
If you need a manual type HOTPOINT USER MANUAL in your browser bar.
Click on hotpoint web site and then user manual and download your model.
Dec 14, 2008 | Hotpoint BWM12 Front Load Washer
Aug 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
