  • 363 Answers
Posted on Oct 24, 2007
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
Primary Master (Samsung HD080HJ/P) Your drive did not fail the self-test, but it returned with an unknown return code: 15
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
also you might try
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 18, 2011 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Change region codes for a samsung hd080hj
control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location
hope this helps
Dec 14, 2010 | Computers & Internet
I can nor write to the CD or DVD I had Samsung SH-S202J
If your CD is broken, it will need to replace it. They do go bad and are fairly easy to repair. var fctb_tool=null; function FCTB_Init_ff57d84afbb142d4861ec25b5e6da39c(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d5afe153f6dd4973b33fa212be83faa4(t) { fctb_tool=t; start(fctb_tool); }
Nov 29, 2010 | Samsung Computers & Internet
On start up it blue screens. HD check gvies Return Code 7
The hard disk is dead. To recover some of your files from it just boot from a Linux Live-CD like  and copy whatever you can recover to a USB memory stick.
May 19, 2010 | Dell Dimension 3100 PC Desktop
Need to set Samsung HD080HJ/P as slave, what pins do I need to jump
remove all the jumpers then it will work as slave
Mar 20, 2008 | Computers & Internet
Samsung SP0411N HDD, error message while booting shows "Pri Slave Drive - ATAPI Incompatible" "Press F1 to resume"
Hi guies ,
                   you haven't specify which kind of error message displayed on screen ,please  do same
Oct 19, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
