Question about Hotpoint Ovens
Control panel instructions gone after cleaning
HOW CAN I CLEAN BEHIND CONTROL PANEL TO REMOVE FATTY DEPOSITS ON THE BACK OF THE GLASS
The deposits can be a bit of a challenge as they re on the inner door glass and may be cooked on the glass. You must remove the door off the hinges first and then remove the inner door panel. It will be attached by screws. Once the inner panel is removed, you can remove the glass and clean it with a product called Goo Gone.
Oct 25, 2015 | Ovens
Viking replacement decals / stickers: Has anyone found a reputable source of replacement decals for oven and cooktop - mine rubbed off after a few years' use, and from cleaning....)
Try www.ovenlettering.co.uk. Mark the owner will find accurate decals of your cooker confirm it with you and send you two sets plus degreaser. Follow the simple steps from the sites video instructions and voila. It is so easy and I highly recommend Mark and his product. Tell him Shaun sent you.
Jan 08, 2014 | Ovens
I cannot find my owner's manual. I need to clean my oven, but I don't have the instructions and the lights have gone off on my panel.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 05, 2011 | Jenn-Air Ovens
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
Cleaned oven and now the fan will not quit and door is still locked has been over 2 1/2 hours since cleaning over.
the timer in the control panel is still regeristing heat! and when the sensor weakens with age it keeps the circuit closed till all heat is gone in the oven area~ to get the door open? unplug the oven or trun off the pwoer to it!! for 15 minutes then turn it back on and it will release you just need to replace the oven heat range sensor for the self cleaning cycle
Jan 23, 2010 | Ovens
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Oct 15, 2009 | Ovens
RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
Mar 25, 2009 | Ovens
Ovens Logo
12 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
