Question about Lands Phones
Vtech phone manuals
No dial tone 'unable to call try again' on two of the phones. How do I fix this.
SOURCE: motorola codless phone
Had the same problem and went to the Motorola US Web Site, FAQ for Out of Range - solution worked perfectly - see link below, you may have to copy/paste into your browser's address area
https://cordless.custhelp.com/cgi-bin/cordless.cfg/php/enduser/std_adp.php?p_faqid=13471&p_created=1174587747&p_sid=kw73CX_i&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD03ODkmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=&p_topview=1
isabelta@hotmail.com
Posted on Mar 29, 2008
SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
SOURCE: vtech phone problem Model # LS6117-5 DECT 6.0
take out battery for a few seconds then put back in. My phone just did the same thing and it kixed it. Not sure why it happened though
Posted on Jan 20, 2009
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
When I dial out on my Vtech phone, it goes back to a dial tone or a busy signal
Are you sure that the phone is even trying to dial? Push 1 digit and make sure dial tone is going away. Could be bad dial pad.
Apr 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to change a vtech phone to tone
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual. The manual will explain how to switch your phone between pulse and tone dialing.
Nov 21, 2013 | Vtech Lands Phones
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
No dial tone
Sep 04, 2009 | Vtech Lands Phones
I can't dial out from my handsets
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Thanks,
monotary
Nov 06, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
