Question about Drills
Makita rotary hammer
Bit falls out
  • 2712 Answers
SOURCE: usage Problem
Yes, but you have to use an auxiliary 3 jaw chuck adapter and you do it.
Posted on Aug 27, 2008
SOURCE: makita HR2455X rotary hammer leaking "oil"?
Apply less pressure and ignore oil.
Posted on Apr 14, 2009
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Posted on Oct 11, 2009
  • 969 Answers
SOURCE: DeWalt 567 rotary hammer won't hammer
If still under warrenty local Dewalt store will repair. Total rebuild $99.00 on most tools.
Posted on Nov 07, 2009
deme-tri
  • 90 Answers
SOURCE: I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Posted on Dec 03, 2009
MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
Makita
possible broken spindle or gear in the gear case
Aug 26, 2012 | Makita HR3851 Electric Rotary Hammer
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
Drill/chisel drops out when useing
if it is the pull-back locking system to hold in the chisel, or drill bit, then the locking- clutch mechanism is worn and needs replaced
Jul 22, 2009 | Makita HR3000C Electric Rotary Hammer
Drill bits do not lock in chuck or will not go in at all.
If the picture that I am seeing is of the same that you have then I can tell you that those are special bits that are fluted on the shanks so they can hammer. Also those drills do not chuck up like a regular drill. You have to pull the collar down insert the bit and rotate it until it falls in and then release the collar. Remember these bits are specific to the drill and can be hard to find, a rental store is a good place to find them for sale. Hope this helps. 2rns4u <*{{{>(
Apr 04, 2009 | Makita HR3000C Electric Rotary Hammer
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Usage Problem
Aug 27, 2008 | Makita Rotary Hammer 260 Rpm, 2100 Bpm, 11...
Drills Logo
61 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
