Question about Petco All-Weather Outdoor Paw Protection for Dogs, Medium/Large
I was given as a gift last year nov. all weather outdoors paw protection and they are already falling apart what do i do i got them as a gift?
Being the product has guarantee 100% what does petco do to solve this problem?
Intermittent starting problems with my 1990 Honda Accord
Have you looked into your crankshaft sensor
Jan 22, 2014 | 1990 Honda Accord
What are the benefits of dog boots?
Dog boots offer many benefits:
  • They protect the dog's paws from different materials like glass, grass horns, and stones.
  • They protect the dog's paws from both the heat and the cold.
  • They are very beneficial for senior dogs who have more sensitive paws.
  • They protect from the slippery floor of the house.
Sep 10, 2012 | Dogs
I have purchased two more Keurig coffee makers as Christmas gifts, but the one I purchased last year will not release water to make coffee. Is this a common problem? If so, I need to return the two new...
Sorry to read about your problem, I hope this helps you out.
no it is not a common problem, but if i am correct COSTCO, should take take it back, even after the 1 year factory warranty.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Keurig B60 Coffee Maker
My HB31R runs slow. Is there any adjustment ability to the timer mechanism to achieve a correct 24 hour timer.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
HB31R heavy duty 1800 Watt outdoor plug-in timer is one-piece unit that does not come apart for repairs.
Usually with these mechanical dial timers, when the clock motor starts getting weak, the timer dial starts to stall when tripper meets on-off lever.
And then timers runs slow.
At this point, the little plastic gears are getting stripped out, or the clock motor is overheating.
In either case, the clock motor is spiraling downward.
If this is new timer, take it back.
If this is older timer, the manual and fact sheet do not show a warranty.
New HB31R on ebay for $15
http://compare.ebay.com/like/250558888618?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=181711814537&crlp=1_263602_304662&UA=WXF%3F&GUID=c8511cb512c0a0aad3e705a7fffd84ab&itemid=250558888618&ff4=263602_304662
Woods makes 1200 Watt outdoor timer, but lighter weight than Intermatic:
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
With larger heavy duty outdoor timers like the Intermatic T-101R outdoor 120Volt timer, you can buy the clock motor separate and replace when clock goes bad. And you can buy the trippers separate. However T100 series timers are not plug-in, they are hard-wired. T-101 is made to last 10-15 years, but cost $60-70. My local Lowes sells them in stock for less.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 08, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Can I use the Intermatic EJ500CH timer in an outdoor box?
No as long as the box is well insulated.
The operating temperture must not fall below - 5
May 24, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Weather station giving wrong outdoor temperature all of a sudden
check if you have the US standard or international standard, like FD. or CD...........
and check your pda the loation where you set is right.
and try to reset a new website for your PDA weather software for updating. becasue different websites may be vary
Jan 10, 2009 | Computers & Internet
Petco All-Weather Outdoor Paw Protection for Dogs, Medium/Large Logo
643 people viewed this question
Top Petco Dogs Experts
Ruth summersides
Gary Clark
Gary Clark
Level 1 Expert
Are you a Petco Dog Expert? Answer questions, earn points and help others
