Question about RCA R52WH73 Projection Television
R52wh74 wont turn on. no sound or pic.
When i plug it in and press the power button green power light flashes three times. other threads say that i need to replace capacitors and or fuses but i dont know where to find these peices. can anyone tell me where to find them or send me a picture of them that would be great.
  • ratherbgolfn May 22, 2009
    could you try and send the picture again. u can email it to me at lets_go_noles@yahoo.com.
  • RCA Master
  • 8,617 Answers
Heres the capacitor locations you can feel the top with your finger if theyre domed they need to be replaced. They should be completely flat.r52wh74 wont turn on. no sound or pic. - f3a8076.jpg
Posted on May 21, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Re my pixma mp13o printer. message"ink waste tank almost full" how do I rectify it. tried switching on and off and unplugging for 10 seconds.
Three choices. 1. Take it in for repair. 2.Take the top off and remove and clean the pad. 3. Use the following instructions to reset the printer and continue printing. I chose number 3 and haven't had any problems.
These are the instructions which worked for me on my Canon mp470 and has work on many other Canon models:
1) Close the print2_bing.gif head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 24, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon IP3000 error code
read entire solution first, see the 6 modes section.
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
PIXMA IP 3000 service error 5100
to fix it
1. Turn off printer
or: and Also;
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
RCA R52WH73 Projection Television Logo
318 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
