Question about Reptile
How many florecent tubes will a 70w ballast suport
How many tubes will a 70w ballast sort
2 Suggested Answers
SOURCE: Im putting together a dual bulb florecent light plug, The ballast only has blk n wht wires is there any ground ??
Most of them have a green screw on them for mounting the ground wire.
Posted on Aug 17, 2014
I have a building full of 427G lights with 12-15 that won't work, but appear to have good bulbs. What is the issue?
Florecent or the yellow HPS bulbs? If HPS you have a bad bulb, or bad ballast. May be similar issues if florecent.
Mar 05, 2015 | Lithonia Lighting Home
How do i connect a ballast
Hello. Not sure what ballast you are looking for but I am guessing a Fluorescent light replacement ballast. Normally in a 2 tune balleast there are a BLACK and WHITE, These are Hot and Common. 2 Yellows go to the one end of the tubes. The 2 Blue wires go to the end of one of the tubes and the 2 red wires go the end of the other tube
Black to Black, White to White. 2 yellow to Tube 1 and 2 yellow to Tube 2. 2 Blue to Tube 1 and 2 Red to Tube 2.
Hope this helps..
Nov 04, 2012 | Televison & Video
I am replacing one of the two ancient ballasts in a four tube fixture that has four F96T12 75W tubes. How do I connect the two blue wires in the new ballast? The old fixture has only one blue wire per...
I don't believe you have the correct ballast for your light. Your old ballast was the old iron ballasts they used to use. They still are available but you have to search around to find them.
Be sure to match the tube wattage, length and diameter as closely as possible.
Here is a website that has a good explanation of ballasts, the old iron ballasts and the newer rapid start ballasts: http://www.repairfaq.org/sam/flamp.htm#fb
Section II. deals with ballasts.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie andie
Apr 15, 2011 | Garden
TV is making a buzzing noise coming from the back interior. We tried checking the cables and testing speakers, neither of which are the problem. Any thoughts?
This noise is coming from the Lamp ballast. The back light of your TV (to make your LCD picture light up) is a Florecent Light Array. It is powered by a lamp ballast. You can have a shop change this power supply out for you.
Jan 06, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have sound but no picture
There is either one of two things,
1) your florescent lamp power supply has gone bad or
2) part of your power supply has gone bad
The only last thing is that one of the florecent back light tubes has taken out all the rest of the tubes.
Can you still see some type of image when you depress the menu button?
Nov 16, 2009 | LG 42LC2D 42 in. LCD HDTV
Changes it's own channels volume and source even
Try to cover the remote sensor on the tv,if this sorts the problem out then it could be florecent lighting that can cause this.
Nov 07, 2009 | H&B HP-5000-B-N 50 in. Plasma HDTV
50" Maxent Plasma TV now takes almost 5 min to "warm up". Starts black then flickers to a decent picture
you need to have a licenced repair tech come look at it sounds like the inverter is going out its kinda likea ballast for florecent lights
Oct 28, 2009 | Maxent MX-26X3 Television
I am unable to install games on my samsung star gt 5233
My samsung Star GT S5233 Mobile Not Suported Jar/jad File and I which file Suported My Mob ?
Jul 27, 2009 | Samsung SGH-L700 Cell Phone
How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Open Questions:
Reptile Logo
63 people viewed this question
Top Reptile Experts
Tom Chichester
john h
ray gallant
Are you a Reptile Expert? Answer questions, earn points and help others
