Question about Razer Computers & Internet
Surround sound not working - Razer Computers & Internet
Reset timer on tv and why surround sound doesnt work when int use to
The Timer and Sound are two different options and neither one should interrupt normal operations. You should open the TV Manual and follow the directions on setting up the Surround Sound. Forget the timer for now. When you get the Surround sound feature back....see if all functions work in concert. If the Surround fails after reestablishing the proper format; you may need to contact technical services at Panasonic. Have them walk you through the process.
Dec 19, 2013 | Panasonic Televison & Video
No surround sound in TV mode
Surround sound will only work if the source signal is coded as surround. Many older TV broadcast programs are stereo only. If your surround sound is working with a DVD or blu-ray then the broadcast source is the problem
Dec 02, 2013 | Denon AVR-1506 Receiver
No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Dec 20, 2009 | Audiovox 150W DVD Home Theater System -...
Surround sound won't work
Try Googling (sony)(STR-K840P)(manual) without parens.
May 25, 2017 | Audio Players & Recorders
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Surround Not Working on TV
well for one thing .. on cable it has to be in surround sound.5.1 or 6.1 for it to true surround.your dvd and cd will be fine .. if you just want to have sound coming out of all speakers you have to adjust your sound settings but it will not be surround sound though
Nov 24, 2006 | Sony DAV-DX250 System
Computers & Internet Logo
Top Razer Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
