Replace bulb I NEED TO REPLACE THE LICENSE PLATE LIGHT BULBS IN MY 1999 CHEVROLET SUBURBAN C2500 SERIES. IT LOOKS DIFFICULT TO GAIN ACCESS, DUE TO THE MASSIVE RECEIVER HITCH BEING IN THE WAY. CAN YOU HELP, THANKS!
SOURCE: TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Posted on Nov 01, 2007
Slinteriors
  • 8617 Answers
SOURCE: Philips 60 rear projection hdtv looks 3D
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Posted on Feb 02, 2008
Slinteriors
  • 8617 Answers
SOURCE: REPLACEMEN BULBS
just a screw driver. very simple to replace the lamp. Just dont touch it with your fingers as this will shorten the life of the lamp.
Posted on Mar 27, 2008
  • 2920 Answers
SOURCE: Projection bulb replacement
the bulb is usually between 4 to 600 and they are not hard to replace if you take your time with it
Posted on Nov 03, 2008
  • 1861 Answers
SOURCE: rear license plate light 2003 Camry
The bulb number that you need is #194.
Pull off the interior trim, and you will see the sockets for the bulbs.
Thanks for selecting FixYa to answer your question.
Posted on Dec 08, 2008
Tail lights work but why don't license plate lights?
The license plate lights have their own separate bulbs. If you are able to replace the bulbs, that may solve your problem. If not, you may have a loose or rusted connection to the plate bulbs only. If you are able to gain access, you may want to check the condition of the harness that supplies the power to the license plate portion. Good luck and have a great day.
Aug 30, 2015 | 2001 Toyota Tacoma
How do I replace license plate bulbs on 2004 park avenue
I was wondering if this was a trick question.
If you don't see little screws holding the light cover on, you will have to access them from inside the trunk.
remove/replace.
Feb 02, 2013 | 2004 Buick Park Avenue
I was "politely" informed by
You should be able to access the bulbs by unscrewing the license plate lamp housing. Its typically held in place by a couple screws, then you remove it and pull the bulb out of the socket and replace.
Jul 22, 2011 | 2003 Chevrolet Malibu
Need to replace bulbs that lights license plate. License plate and light is part of trunk
raise trunk lid look on the inside behind your license plate light there should be access to the bulb there. You will see the wires going in to the bulb there will either be a flt plate that can be removed to access bulb or where the wires enter there will be a round socket that you can twist counter clockwise and remove the bulb socket for bulb replacement. hope this helps.
Jan 15, 2011 | 2003 Lincoln Town Car
I need to replace the bulbs above the license plate on my 2002 eldorado how do you replace them....get at the old bulbs
Hello: Remove the license plate, then remove the screws on the chrome piece behind the license plate and the you can access the bulbs.
Nov 24, 2010 | 1999 Cadillac Eldorado
License Plate Lamp Replacement on 1999 Cadillac Eldorado ETC. Where is the access point for replacing the licence plate lamps?
Hello, remove the rear license plate, remove the housing where the license plate was mounted, now you can see how to replace the bulbs.
Sep 05, 2010 | 1999 Cadillac Eldorado
How to replace license plate light on a 2002 buick lesabre
Hi. Remove the retaining screws from the license plate light assembly with a Phillips screwdriver. There are two screws on each side of the lens assembly.
Pull the light assembly cover down out of the way to gain access to the bulbs. Twist the bulb socket counterclockwise to remove it from the assembly and pull it straight out. Pull the bulb out of the socket.
Push the new bulb straight into the socket. Replace the bulb and socket inside the light assembly and turn it clockwise to secure it.
Replace the assembly cover and secure it with the retaining screws. Tighten the screws with a Phillips screwdriver. Turn on the lights to test your new bulbs.
Take care
Aug 04, 2010 | 2002 Buick LeSabre
Burned out license plate bulb
open trunk,
remove felt liner from rear of trunk, (liner directly behind rear lights in side trunk) should be 4 plastic Phillips head screws. Loosing screws, then slowly peel liner away. You will see 3 nuts on each side, removing these nuts will loosing the rear light lenses, so you can pull the lense away from the body from the out side to gain access to the license plate bulbs. Re-install in reverse order. While in there I would recommend replacing your brake light and reverse light bulb. Hey your already in there might as well do a little preventive maintance.
Dec 12, 2008 | 1995 Lexus ES 300
Rear license plate light 2003 Camry
Dec 07, 2008 | 2003 Toyota Camry
Bulb replacement
you have to go through the trunk and remove the fabric to gain access to the plugs/socket.bulbs.
Sep 03, 2008 | 1999 Infiniti.5 QX4
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
