Question about Acer AL1716 17" LCD Monitor
LCD showing wrong colors
Hello, I have an lcd where the colors where fine before. Then one time when I restart my pc the lcd autoconfigs by itself and is showing the wrong colors. It is now too bright and a little too "red". Everytime I hit the autoconfig button it shows the correct color (the one before) for a moment then finally it decides that to settle on the wrong colors.
  • kenth_kristo May 21, 2009
    I'm not sure. But it's about 2-3 years old.
  • oGyNc May 11, 2010
    how old is the lcd?
    Problem Solver:
  • 7 Answers
I believe it might be dieing. you can get a 19 - 20" for around 120 - 140$.
Posted on May 22, 2009
LG 47lv5500 shows wrong colors
Hi, Probably you are gonna have to change the main board! Best Regards! Bye!
Serge!
Jul 03, 2015 | LG 47 47LV5500 47 LCD TV
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
Dell display failure
8 Beep Codes means its a Display failure. It could be a problem with the Motherboard or the LCD display itself.
Turn off the system. Press and hold down the 'D' key and press the power button once, do not release the D key you should see a set of colors on your screen.
If you do and the colors are fine then there is nothing wrong with the LCD display and the problem lies in the Graphics controller on the Motherboard.
Please call Dell Technical Support for appropriate part replacement.
Jun 18, 2012 | Dell Inspiron 14 14r N4010 Black Cover Lid...
My dell inspiron e1505 would simply crash and show a black screen whenever I run a video online on fullscreen. It would stop responding to anything and I would have to force shutdown and then restart and...
Try running the LCD Bist Diagnostics. Press and hold the key while powering the system on. This will start the Preboot System Assessment (PSA) diagnostics which includes a test for the LCD.
In the process of running the PSA, if the graphics test error (0334 or 0333) is given and the user presses "Y" to continue testing, the LCD BIST will begin. During the LCD BIST, a solid color screen is shown and 5 different colors are displayed. While the colors are displayed, the system beeps every two seconds and the lock lights (Num Lock, Caps Lock, and Scroll Lock) illuminate to indicate that the test is running. This can be used to determine if something is wrong with the display.
While running this test, the LCD is operating on its own, free of the video controller which may be discrete (a video card) or onboard (on the system board). The test allows you to tell an LCD panel problem from a problem with the controller. If the colors are displayed across the screen without a problem then the issue lies outside of the LCD.
Aug 05, 2011 | Dell Inspiron E1505 Notebook
My LCD Don't show white color. It's shows pink color instead of white. If there is setting fault, please tell me the procedure of correction.
Hello
The CFL (cathode florescent lamp) of the LCD has gone bad, it needs replacement, because i faced same problem some time ago and only solution is to replace CFL.
Good Luck
Jan 28, 2011 | Televison & Video
I have a gateway m675 and it has something wrong with the lcd screen. In the right hand corner the is a band about 2' wide and runs top to bottom. The colors are inverted looking that area and the tint of...
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Sep 03, 2010 | Gateway M675 Notebook
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Screen showing funny lines and colors.
That would be the screen itself that needs replaced, if you needed the inverter board you screen would be dark and hardly visable
Nov 12, 2008 | Acer Aspire 3100-1405 Notebook
White screen, have to do a soft restart and then words show up
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Jul 09, 2008 | Apple iPod MA446LL/A MP3 Player
Acer AL1716 17" LCD Monitor Logo
361 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
