Question about Home
Where do I find an aquajet shower installation manual
There doesn't appear to be enough hardware with the shower
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
I just installed a Moen Traditional 82008BRB faucet and shower. After having it installed for a day, water will drip (20 or so drops) out of the shower head every 5-10 minutes. This also occurred when I...
HELLO- Very possible that there can be dirt or solder inside, hard to determine without looking inside at the sealing points of the vavle itself. Try to determine if it is the hot or the cold side,also look at were the valve seals off ,could be small imperfection in the seal ! Good luck
May 17, 2011 | Moen & One Handle Tub & Shower Faucet
Years ago I purchased a Kinkead Vista-Pivot Shower Door, model 1500-31, Silver. For a variety of reasons the shower didn't get built until recently. However the door opening is now 32.5 inches wide so it...
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Mar 16, 2011 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Is it difficult to instal a new shower head?
It requires a piper wrench or chanel lock pliers. If you are able to unscrew the old one,you wil have no problem screwing on the new one. Use teflon tape on the male threads when installing the new one. You can even screw it on by hand only needs to be tight enough that it does not leak . It unscrews counterclockwise looking at the end of the spray head.
Apr 23, 2009 | Plumb Pak Economy Shower Head Water Saver
Leaky handshower hansgrohe croma c100
Grab a wrench and give it at least a quarter-turn. Hand tight isn't enough with a shower, even with teflon tape.
Mar 28, 2009 | Hansgrohe 04070930 Croma C 100 3-Jet...
Installation of shower panel -26345001
If i can get the make and model # I will look for the manual for you.
Nov 12, 2008 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
