Question about Muratec MFX-1430 Copier
Muratec 1430 Lamp Error
I pit documents in the scanner window to send and I receive a 'Lamp Error".
I turn the machine off for a few minutes and restart it and it works properly,
What causes the error and should the lamp be replaced?
Thank you in advance
    Genius:
  • 1,218 Answers
This may be a case of "older software" there were numerous software updates to the 1430...the last being Dec'2007 upgrading to a software level D6AOAO.
You can print out a Consumable Order Sheet to check the ROM version of your machine.
Press...SETTING, *,1, 5. Select "OrderSheet List" when printed..at the lower Right hand corner is the Rom version, if it is A ****, OR B****
or lower than D6 then it is likely the software needs to be upgraded...this will require a service technician with a Laptop to do the software upgrade.
Posted on May 28, 2010
What does it mean when my Muratec Fax Machine says DHCP Server Did Not Respond and it will not send or receive documents?
DHCP is the way systems on a network get an address from the network. In a home environment, that's usually done by the router. Unless your fax machine is attempting to send faxes via the internet (rare), that isn't why your machine can't send or receive a fax. If you're talking about sending a fax from your computer, then not having an address is indeed the reason you can't send a fax from your computer.
You will need to see why your router isn't giving the fax machine an ip address. Is it connected to the router? Wireless? Wired?
Jul 08, 2015 | Muratec Office Equipment & Supplies
I have a Muratec F-68p fax which display ( call service (2) )what should i do ?
I believe the error code you are getting on your display has to do with the "scanner" that copies the printed document that you are trying to copy or send out a fax. The scanner is not bright enough to do its job. Moisture or a very dim-lighted scanner will trigger this. This needs to be removed by a printer /fax machine repair person. Hope this helps, Steve
Nov 05, 2014 | Office Equipment & Supplies
DHCP server did not repond
Mat be your dhcp server is not up.please enter a static ip which is not in range of your dhcp server.
Oct 08, 2014 | Muratec Mfx - 1430 Fax, Copier, Scanner &...
I am attempting to set up a Muratec MFX-1430 printer for a client and it does not seem to be communicating via the network. I have it plugged directly in to the Belkin wireless router that the desktop PC...
IF YOU HAVE THE INSTALLATION CD THAT WAS SUPPLIED WITH THE MACHINE THERE IS A "MANUAL SECTION" IN IT THAT EXPLAINS HOW TO SET UP THE INSTALLATION.
iF YOU DONT HAVE THE CD YOU CAN DOWNLOAD IT FROM MURATECS WEB SIT AT THIS FOLLOWING LINK http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp
Oct 01, 2010 | Muratec MFX-1430 Copier
Does anyone know of a reliable source to get Muratec Fuser assemblies repaired or at least a source to purchase the parts? Specifically the MCX 1430 or 2050. thanks,
The 1430 and 2050 fuser units are differently "geared" due to the speed difference the 2 machine run at. To find a local dealer who can help with parts...give Muratec Tech Support a call at 1-800-359-7035 and they can likely tell you who to contact in your local area.
Sep 01, 2010 | Muratec MFX-1430D Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
290 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
