It is still freezing but alarm will not hold on reset. Even after unplugging it for a short while. Door ajar light stays lit on front panel.
SOURCE: Kenmore Freezer Alarm
The battery was the problem in ours. It was doing the same thing. We went through a whole bunch of stuff trying to figure it out too since we bought it as a floor model only two weeks ago. It's just a 9 volt battery.
SOURCE: the temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
SOURCE: alarm on door keeps peeping red
The door switch which senses when the door is ajar needs to be replaced or cleaned. See if you can make the alarm go off by pushing the switch in as far as it will go or take the switch out and by pass it by taping the wires together. There's a sensor switch for each door so try each one separately.
SOURCE: Door alarm light is on
The open door alarm is triggered by the small switch that also triggers the internal lighting. This is easy to test: open the door and press the switch - on a normal one the light should go off.
This is the switch
http://www.bizrate.com/refrigerator-accessories/oid1852839097.html
And here is in the parts manual page 4 part 14
ftp://ftp.electrolux-na.com/prodinfo_pdf/stcloud/5995552030.pdf
SOURCE: door was not sealed tightly
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Thank you for your post, friend!
Based off what you are describing it sounds like a possible issue within your control panel or door switch of your Frigidaire freezer, LFFH21F7HW6. You have completed a reset on your appliance by disconnecting power. I would recommend seeking assistance from a professional to properly diagnose and repair your freezer. Hope this is helpful. -Matt
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
