Question about AmbiCom Air2Net BT-PA (BTPA) Print Server
I lost my pairing code and now i can't pair my computer with the ambicom
Pairing code ambicom bt-pa
No pairing code needed. Just hit next.
Jan 02, 2014 | AmbiCom Air2Net BT-PA (BTPA) Print Server
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
Need to know how to pair lost pairing info
first you have to turn the power to blue tooth on ,then you will have to put ur speaker into discovery mode,most blue tooth manufactures use the power button for this feature by holding it down for 6 to 10 seconds when turning on the device it will put it into discovery mode,your phone or computer or game system should be able to recognize the blue tooth device then.It will ask you for a pin pairing code,now most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 hope this helps
Feb 26, 2011 | Blueant Sonic Bluetooth Portable Speakers...
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Have a nice day.
Sep 01, 2010 | Cell Phones
I lost the instructions that contain the unlock code to enable bluetooth access... I got one of those bluetooth adapters for my computer and i'm trying to pair my computer with my mobile phone. My phone is...
If you want to pair the phone with the PC through BT then all you have to do is to give and number like 00 or 0000 as the code. on the phone and press enter. Then the PC will ask for the code. You should give the same number there too, ie, 00 or 0000, whatever you gave earlier. Then the phone will connect to the PC through BT.No instruction manual is required for this. Once your phone and PC are paired you can set then to connect with out this code being given every time.
Dec 04, 2009 | Computers & Internet
Bt 70r instruction manuel needed need manual or details how to pair bluetooth in car device
BT70R pairing with a new phone
The code for pairing with a new device is 0000.
However, the BT70R retains the identity of the phone that is is paired with and this old code must be removed before a new phone can be paired. There is probably something in the manual for this, but I have lost my copy. Here's how I got round the problem...
Place the BT70R in a sealed plastic bag (to protect it from moisture) and then put it into your freezer and leave for 24 hours. When you take the BT70R out it should have lost its memory of your old phone and you can pair it with the new one.
It worked for me!
Oct 21, 2009 | Car Audio & Video
Bluetooth pairing code for Intempo BT-01
The pairing code is 0000. Turn off your BT-01 then back on again. The blue light flashes quickly. Only during that time can you pair with it. Good luck, Andy W
Apr 30, 2009 | Audio Players & Recorders
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
AmbiCom Air2Net BT-PA (BTPA) Print Server Logo
Top AmbiCom Computers & Internet Experts
David Payne
David Payne
Are you an AmbiCom Computer and Internet Expert? Answer questions, earn points and help others
