Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ul code machine do not essore
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: error code F1 and UL
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%#
Posted on Sep 20, 2010
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
Ul code on empty machine
Sounds like you need to replace the bearings... not a difficult task. http://appliancejunk.com/forums/index.php?topic=8960.0
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Unlock my phone
Dear sir, How are you, I'm sending you some codes and I hope these codes will surely help you out.:)
Nokia Code & their function:
  • *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
  • #3370# Deactivate Enhanced Full Rate Codec (EFR)
  • *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
  • *#4720# With this Nokia code you can deactivate the Half Rate Codec
  • *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
  • *#9999# Phones software version if *#0000# does not work
  • *#06# For checking the International Mobile Equipment Identity (IMEI Number)
  • #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • *#147# This lets you know who called you last (Only vodofone)
  • *#1471# Last call (Only vodofone)
  • *#21# This phone code allows you to check the number that "All Calls" are diverted to
  • *#2640# Displays phone security code in use
  • *#30# Lets you see the private number
  • *#43# Allows you to check the "Call Waiting" status of your cell phone.
  • *#61# Allows you to check the number that "On No Reply" calls are diverted to
  • *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
  • *#67# Allows you to check the number that "On Busy Calls" are diverted to
  • *#67705646# Phone code that removes operator logo on 3310 & 3330
  • *#73# Reset phone timers and game scores
  • *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
  • *#7760# Manufactures code
  • *#7780# Restore factory settings
  • *#8110# Software version for the nokia 8110
  • *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
  • *#94870345123456789# Deactivate the PWM-Mem
  • **21*number# Turn on "All Calls" diverting to the phone number entered
  • **61*number# Turn on "No Reply" diverting to the phone number entered
  • **67*number# Turn on "On Busy" diverting to the phone number entered
    Good Luck. :)
Dec 16, 2009 | Motorola Mobility E770 Cellular Phone
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code up and before that just cut off during load
The ul code is unbalanced load. Try adjusting the load. If it happens again try removing some of the clothes.
Mar 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
