Question about Microwave Ovens
Neff h5640 microwave
Turntable not rotating
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: the turntable in the microwave does not rotate
First you need to see if it is the motor that is bad. Usually you find the relay or switch that powers the motor and see if you have voltage.
Microwaves are better left to professionals. A novice could hurt themselves working on a microwave. I would suggest getting a repair man to fix it or buy a new microwave (whichever works out cheaper for you)
Posted on May 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Jun 12, 2009
  • 3230 Answers
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
My H5640 microwave has stopped heating food and cuts out after 40 secs - is there a reset button or is it a "bin and buy another one" job
Sounds like it's time for a new oven. The magnetron tube that makes the microwaves is overheating and causing the safety thermostat to cut off power. Normally, with the cost of the replacement tube and repair labor, it's more economical to buy a new oven.
Jun 13, 2010 | Neff H5430 Convection Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
My microwave does not heat up
i would think the cost involved would warrant better spent on a replacement good luck
Jan 11, 2010 | Neff Microwave Ovens
Neff 5470 used for 20 min then just cut out
Take it back to where you bought it from and get a new one!
May 19, 2009 | Neff H5470NOGB 900 Watts Microwave Oven
Turntable Doesn't Rotate in Neff H5642 (1000w)
I'm sure your motor has failed.
Sometimes it a broken post inside the motor, if you like to tinker.
Otherwise I would contact Neff's service people for a spare.
Aug 22, 2008 | Neff H5642 Convection / Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
