Question about Dishwashers
Whirlpool dishwasher du1055
Hi My whirlpool dishwasher du1055 5 years old not cleaning well, not taking the soap completely.I kept the plates after hand wash for sanitising it comes with dirt , can you pls help me?
catriver
  • 878 Answers
SOURCE: Kenmore dishwasher 15899100
Dennis, Im assuming your model number starts with 665. This model had a service flash on it regarding the upper spray arm. The upper spray arm has been redesigned for better performance. Part number 8269022. This could be covered by Sears if you mention the service flash, 22-714. Other issues that can lead to this problem are; water hardness, if your water is over 7 grains of hardness, this could to this film on the glasses. Try pouring 1/4 cup of Glass Majic into the bottom of the dishwasher. Also run one cup of white vinegar to clean the dishwasher. Make sure the water temp. entering the dishwasher is 120 min. to 150 degrees. Catriver..post back.
Posted on Oct 30, 2006
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: my dishwasher is not cleaning dishes - it is
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Posted on Dec 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE dishwasher will fill then it stops. The wash
The pump/motor combination is stuck.
Disconnect power to the unit.
Remove the toe-kick panel at the bottom front.
You will see fan fins at the back of the motor.
Turn the fan fins counter-clockwise.Turn to the left and hold the position with a screwdriver. Then turn left again. You will feel when the stuck motor shaft frees itself.
After it frees,resume power and run the dw.
If it does not break free you will have to replace the pump and motor.
Posted on Jul 17, 2010
Whirlpool DU1055 dishwasher keeps rinsing without going to 'dry cycle, to complete the wash. What is the problem? Thanks, David
Hello
There is several things to check:
Heating element: by Ohming it out to check for continuity,
Control board: to check to see if the heater is getting 120 volts to it in Heated dry cycle.
Do you use Jet Dry or any Rinse Aid?
I always advice consumers to use this.
Check your owners guide , you may have a 2-5 yr. part warranty on the control board.
Aug 11, 2011 | Dishwashers
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Does the soap dispenser open automatically during the wash cycle, ours doesn't open and the dishes aren't getting clean.
does the cycle complete?. if it does and your dispensor is not open, then your dispensor is faulty. try opening it by hand, remove old powder, refill with 2 tablespoons of powder,select fast programme and see how you go. if your cycle is not completing then let us know what it is doing instead.
Apr 07, 2010 | Whirlpool Dishwashers
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Our Kitchenaide dishwasher is approximately 4 years old, all my glass ware comes out cloudy and I have to wash it by hand.
Your using too much soap. Use 2-3 tespoons of name brand powder soap. Premeasured gel packs or tablets are too much soap as well. Cut them in half if u are using those. You can run a cycle with 5-6 cups of white vinegar with no soap or dishes to clean the soap residue from inside the dishwasher.
Apr 15, 2008 | Dishwashers
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
