Question about Back to Basics Smoothie Accolade Blender
I need to replace back to basics smoothie z dispensing spout
4 Suggested Answers
fossilruins
  • 114 Answers
SOURCE: Back to Basics Smoothie Plus 600 Spout
replacement parts are available from their website:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
Posted on Jun 16, 2008
  • 351 Answers
SOURCE: I'm looking for replacement parts for a Back to Basics Smoothie
see if this site has what you need ..
Posted on May 09, 2010
Testimonial: "That awesome. Thanks."
  • 1739 Answers
SOURCE: I have a BAck to
Replacement parts for your Back to Basics SE2000 can be found here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=3694&secid=87&linkon=subcategory&linkid=90
Posted on Mar 18, 2011
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Smoothie pro 600
When you find out how to contact Back To Basics you let me know. They don't seem to exist except to rip you off when you buy their junk
Jan 15, 2010 | Back to Basics 600 Smoothie Plus Work Top...
Looking for a gasket for a Back to Basics blender. Black moothie maker with dispensing spout SAIPAA500
Remove gasket and carefully take it to a hardware store that supplies gaskets. Many times a water store will also have gaskets if they work on water filters. There are many types of gaskets, be sure you get the right shape and thickness, or it won't work.
Nov 05, 2009 | Back to Basics Smoothie Elite Work Top...
The pour spout on my Back to Basics Smoothie Freeze has completely cracked off. Where do I get a new container with valve and pour spout?
I am looking for the dispensing valve for my BackToBasic. I'm not sure but I think it is a 700. It is a black dispenser with a chrome base. Please let me know if this part can be replaced. I could settle for a white one but it would look like a "saddle on a donkey" as my husband would put it.
Jul 06, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Back to Basics Smoothie Accolade Blender Logo
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
