Question about Hotpoint Dryers
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Had just dried a load of clothes and when i started to dry the last load, turned the knob and it just buzzed. Tried it again, and it does nothing! This is a hotpoint, front load electric dryer.
  • 6,784 Answers
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
Posted on May 21, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
I have a Kenmore Dryer from Sears Model 97292100. It was working fine for several loads the other day, but when I went out to get the next load out, it had not dried completely. I set it to run again, but...
Is the belt tight around drum. If yes, then there is a tripable thermistor in the heat tube. Small button on it that slight push on it resets device. If belt is loose but not broken, then it is off the tensioner b
May 05, 2017 | Dryers
When we go to turn the dryer on it makes a buzzer sound, how so we make the dyer work?
Is it the same buzz that goes off when the load is finished? The knob may be broken, if so what you need to do is pull it off and see if the handle knob is really turning the smaller knob, if it isn't, replace the knob.
If the knob is fine then you have a problem with your controls and you need someone with electrical experience to look at it.
Mar 13, 2010 | Kenmore 400 6943 Dryer
Loud buzz when dryer turned on drum doesn't turn
Is it the same buzz that goes off when the load is finished? The knob may be broken, if so what you need to do is pull it off and see if the handle knob is really turning the smaller knob, if not, replace the knob.
Mar 12, 2010 | Dryers
Won't stop buzzing
electric dryerwon't stop buzzing
Dec 10, 2009 | Kenmore Dryers
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
I have a buzzing sound before every cycle.
Need model # for exact part look up sound like start cap for motor or bad motor
Apr 28, 2017 | Maytag MAV7501 Top Load Washer
Dryers Logo
300 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
