Im trying to play music on my aiwa CX-ZHT63 via my i phone but only my surround speakers work any advice?
Im using the 5.1ch IN setting and when i press play only my back speakers work not my large front ones they are only connected by wire
  • 3 Answers
SOURCE: rear speaker not working
If you did the 5.1 sound test and the rear speaker works, sometimes you have to see in your software speakers settings,probably you need to change to 5.1 speakers
Posted on Sep 07, 2007
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
SOURCE: Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Posted on Sep 24, 2008
SOURCE: 3 of 5 speakers not working.
normal stereo sound its not 5.1 if your hearing music its stereo and not in 5.1 channels, you need to activate the Creative Sound EAX sorround mix, check on the EAX console, there you can simulate 5.1 or clone the 2.1 channels to the rear speakers, i like more the simulation works better... simply sends some freqz to the rear speakers
Posted on Sep 29, 2008
trav1856
  • 57 Answers
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Posted on Dec 02, 2008
How do I adjust the volume on a aiwa cx-zht63
It's with neither the left or the right circle, try twisting it to the right for more volume and to the left for less
Apr 16, 2016 | Aiwa Audio Players & Recorders
The AIWA CX-ZR525 wont play cd's, it will only pick them up and leave them there with no music
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 14, 2014 | Audio Players & Recorders
Audio problem streaming media via ROKU and RCA players. Constantly have to adjust volume to hear them talk, but then the music/sound effects blast you out.
It sounds like you're using a set of stereo speakers to play a surround sound output. I would try going in the TV menu and turning off surround sound
Dec 23, 2013 | Televison & Video
I have a aiwa cx nhmt75 home theater system which the surround sound rear speakers I believe model # sx-r275 for them has been misplaced or destroyed could you tell me what speakers can be used in place of...
You should be able to use any decent pair of speakers with an impedance between 8 Ohms and 16 Ohms and maximum power capability of at least 33 Watts. The link provided is for the specifications page of the owner's manual.
http://audio.manualsonline.com/manuals/mfg/aiwa/cxnhmt75.html?p=31
Aug 28, 2017 | Audio Players & Recorders
How can i play my ipod on an Aiea CX-NAJ22?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX.
*It'll be advisable to lower the system's volume, so as to not cause any damage to your system or speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
JaHa
Oct 07, 2012 | Aiwa NSX-AJ310 Shelf System
My aiwa surround sound subwoofer is not working. I can here bass when I touch my finger to its cord however. Just isn't working when I play music.
Hi,You did not give make and model of your Receiver !!!
Was it working before or you have just connected it to the receiver..? All surround receivers have a surround Sound Setup procedure that either Activate or Deactivate the Subwoofer..So,pls check your Sound set up and speaker Connectiions on the back of Ampl?f?er.
If problem continues pls let me know with more detailed description.
Hope this helps! Take care and please Remember to rate/vote us
to continue for Helping out the Community :)
Thanks
Aug 21, 2011 | Audio Players & Recorders
I just bought an Onkyo tx-s804 receiver. and some new rear surrounds. Since I am moving, have not set up anything formally, but have plugged my dvd player into the front video 4 input via an optical...
PCM is what it's receiving from the DVD player. The player has output bitstream settings, too, maybe even speaker configurations and distances. Read its manual.
May 11, 2011 | Onkyo TX-SR804 7.1 Channels Receiver
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
Surround Sound Not Playing For TV Programs
Greetings jdm12,
I can understand your problem, I have some what of the same issues with my home theater setup when watching events. One of the only suggestions I can make is adjusting the "Dolby Pro Logic II Mode". After reviewing your owners manual it appears you should be able to change the mode by pressing the PL II Mode button found in the lower keypad on your remote. It appears the options you should have are Music - Cinema - Pro Logic - Matrix - Stereo. You may want to try Music or Stereo when watching your events. In Stereo setting it should provide sound out of the front speakers and sub-woofer only. In Music, there are more processing that is done so you could hear more then just the front speakers.
I hope this makes your next your next PPV Party a big hit!
Jon
Go Ahead. Use Us.
Jun 17, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
14 people viewed this question
 Grubhead
Grubhead
