Question about Canon PIXMA iP1800 InkJet Photo Printer
Print spooler service has been stopped
I can't reinstal printer
  • smskalit May 22, 2009
    I can reinstall driver canon pixma ip 1880
  • Canon Master
  • 13,433 Answers
You need to turn the spooler service On.
press start then run
or hold down windows key and press r
then type in: services.msc
in services find printer spooler, right click on it and select properties make sure the start up type is on automatic and then press start to start the service. apply and ok then close the window ones its started.
go ahead and install the printer.
Posted on May 21, 2009
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: "Error 1068 Could not start the Printer Spooler on local Computer"
Just to add to CoachTim's excellent solution, i find that removing the printer from the usb port as well as turning it off helps. But make sure you uninstall printer completely from add/remove programmes and check in the folder after that there is no canon printer listed. download this UK driver http://software.canon-europe.com/software/0024838.asp?model= Restart your pc before re installing and re connecting printer.
Posted on Feb 16, 2007
  • 320 Answers
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Posted on Sep 07, 2008
SOURCE: Canon mp210 problems print spooler error
Error EP22
Posted on Feb 10, 2009
Roop1980
  • 228 Answers
SOURCE: Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Posted on Apr 12, 2009
Cannot connect with hp printer. a red x appears and says that there is a problem with print spooler
Click Start, Devices and Printers, right click on the Pro 8500a icon for your printer. CLick Properties. From there, click the Advanced tab and choose "Print directly to the printer". Click Apply and OK. From there try printing again.
Report if this works.
Feb 11, 2013 | HP Office Equipment & Supplies
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Printer spooler
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Mar 13, 2011 | Canon Office Equipment & Supplies
Print spooler not running. Dont know whether its connected but ive just had live help from microsoft for sound problem
Hi!
Resolution:
Feb 16, 2011 | Lexmark X1190 All-In-One InkJet Printer
I have an HP 1020 printer. I cannot undertake any operation as the words " printer spooler not running " continues to appear on the screen. I tried to delete the printer and reinstall , without...
Print spooler not running is not the printer error, it happens when the print spooler service starts working in windows, For making it enable you dont have to reinstall the drivers for the printer, as print spooler service is for every printer, even if you put another printer the result will be the same
To Enable Print Spooler Open Control Panel
Go to administrative Tools>Services (For Windows XP Users)
Control Panel\System and Security\Administrative Tools( for windows 7 users)
Open Services Find Print Spooler in the list
Right click the service and make it stop, if its already stop set it to Start and then again give prints
Double click on the service and set "Startup type to AUTOMATIC". You should now be able to get prints from your printer
Now restart your desktop/laptop and check if the service is still working by giving any test print.
Hope it will solve your issue
If you require more assistance, regarding this topic feel free to reply
Regards, BA
Jan 14, 2011 | HP LaserJet 1020 Printer
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Can't reinstall printer- ''print spooler is not working''
If you have the windows disk for it , Save everything important to disks.  Put WIndows  disk into machine and tell it to install. It will find you version and ask if you wish to repair it, Say yes.   If you have Xp pro just "Restore" computer to the date before the problem started. If you have neither one. Save you work and then reinstall everything using your backup disks.
Mar 18, 2009 | HP Computers & Internet
Spooler servis dont work
Resolution:
Aug 25, 2008 | HP Office Equipment & Supplies
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
560 people viewed this question
old marine
old marine
