Question about Electrolux Dishwashers
Fills but does not start - Electrolux Dishwashers
Sometimes water won't flow on certain timer settings. And sometimes starts, then stops.
i would go heavy on the deoxit D5
https://www.google.co.uk/search?q=deoxit+D5&ie=utf-8&oe=utf-8&gws_rd=cr&ei=IhJAVZevEILsat3agcAD
i think your timer control switch
has carbonized contacts...
so perhaps the contactors are blasted a bit
either this or look for a new program control
Apr 28, 2015 | Washing Machines
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Neptune will not stay running during fill
you may have a fill time out issue here
check you hoses
disconnect them and clean the screens
Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher won't always fill with water
if the unit fill the first time you start it after it fill and starts to wash hit cancel let it drain if it fails to fill again 2nd or 3rd time you have a bad fill valve
Aug 20, 2009 | GE Dishwashers
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
