Question about Brother SX-4000 Typewriter
My sears electric typewriter SR3000 161.53680 only types the bottom part of lower case letters.
SOURCE: typing different letters than what i am striking
How do I set keyboard 1? I see 2 and 3 on the keyboard but I don't see 1. Where is it? What letter is it on it?
M
Posted on Dec 14, 2007
squipps
  • 204 Answers
SOURCE: typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Posted on Feb 06, 2008
JayBlair
  • 328 Answers
SOURCE: typewriter not typing correctly
check to see if their is a keyboard selection switch on the keyboard.
It may have a setting that says international, symbol, standard, etc.
Posted on Aug 12, 2008
  • 120 Answers
SOURCE: Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Posted on Nov 13, 2008
  • 215 Answers
SOURCE: My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Posted on Feb 27, 2009
Why only top part of lower case letter is printing. The top part of the j prints, but the tail doesn't?
If it is just the "J" that doesn't type all the way then the printwheel is damaged. If it is all of the letters then the roller (platen) may not be snapped down all the way on either side.
Feb 18, 2015 | IBM Series 10 Wheelwriter 2 Electric...
Bottom part of lower case letter not printing
If the problem is just one character that is not printing the bottom then the printwheel is damaged and will need to be replaced. If it is all of the characters then the platen (roller) may not be snapped down on either side.
My smith corona sl 570 is not printing the letters c,v, b and n in both lower case and upper case. how can i fix this?
You have a key board problem. It may just need disassembly and cleaning but more likely it needs a new contact velum.
DickyO
Jan 03, 2014 | Smith Corona Wordsmith 100 Typewriter
Et personal 540 sp wont type capital e
If your typewriter types using a print WHEEL the Cap S is probably broken off. Replace the print wheel
Apr 24, 2013 | Olivetti Office Equipment & Supplies
Capital letters are low compared to lower case letters
You probably have old rubber stops on the shift that have gotton soft or hard over the years and need replaced.
DickyO
May 15, 2012 | Office Equipment & Supplies
I got an really old typewriter for my birthday last week and yesterday i deceided to type a letter to a friend on it. When i was testing out stuff, tabs and things like that, my space was stuck. After...
Your typewriter may just need some lubrication. using a 3 in 1 house hold oil, add a few drops to each letter arm at the bottom where it connects.If possible,use a compressed air source to blow out the entire unit (wear saftey glasses of course), the lubricate the moving key areas. This is the best case fix, worst case would be parts need replacement.
Jun 10, 2010 | Office Equipment & Supplies
Typing only half letters
Possibly the lower edge of the ribbon has become folded over during fitting, it happens.
Apr 19, 2010 | Smith Corona Wordsmith 200 Typewriter
Lower case c
Sounds like it needs a new printwheel.
DickyO
Jun 24, 2008 | Brother Office Equipment & Supplies
Brother SX-4000 Typewriter Logo
35 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
