Question about HP Officejet 6310 All-In-One InkJet Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
Can receive faxes but not send. Getting error code 388. Can hear the other fax machine trying to communicate but our fax machine cannot connect to them.
    Scholar:
  • 191 Answers
The reason for the error code:
Receiving error 388.  Can receive faxes but won't  - 4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
I've been trying to send fax for a couple days now. The fax is connecting, then it never connects and a sheet prints show Error 388. I've tried plugging fax into new jack and all, but it still doesn't...
This error shows that there is too much noise / interference on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Check that the phone cord is plugged in correctly on the printer and in to the telephone Jack. Also check that the phone cord is not damaged in any way. If you have other devices sharing the phone line on the premises or sharing the phone socket than disconnect them to see if this allows the fax to be sent successfully. This could also be a general problem with the phone / fax line outside of your premises and could even be at the receiving end. Try faxing a message to someone else. Then retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 09, 2009 | HP Officejet 6500 Wireless All-in-One...
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Comm error 388
Here's some info and possible steps to take. This is from the HP website.
Error 388 for a HP LaserJet 3050
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON . Follow the steps below to disable V.34 setting.
  1. Press Menu/Enter .
  2. Press the < or > buttons to select Fax Setup , then press Menu/Enter .
  3. Press the < or > buttons to select All Faxes , then press Menu/Enter .
  4. Press the < or > buttons to select V.34 , then press Menu/Enter .
  5. Press the < or > buttons to select OFF , then press Menu/Enter to save the selection.
Hope this helps, samson39
Jul 22, 2009 | HP LaserJet 3050 All-In-One Printer
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
Apr 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Receiving error
Ok...so I fixed my own problem. I had printed out a system data sheet on my fax machine and found out that the "error" was in under sending confirn, so I went into my menu to the sending confirm section and turned it off. Then my boss tried sending the fax and it came through like nothing was ever wrong...I think the other day when my Iguana got in my office, he must have done something, as I found him perched on my fax machine....hmmmm. Thanks for the follow-up email.
Apr 09, 2008 | HP 1040 Plain Paper Inkjet Fax
HP Officejet 6310 All-In-One InkJet Printer Logo
3,268 people viewed this question
Seeker5211
Seeker5211
