Question about Fujitsu Heating & Cooling
Remote control not working
Remote seems to work but wont turn on ac
3 Suggested Answers
  • 19 Answers
SOURCE: I have a split type LG ac and I the remote control
A problem that almost everyone gets but what happens is that sometimes we have notice the remote if the screen looks dim or if it has rust in the battery compartment these are signs of your remote getting worn and also depends on the age of the unit the piece that is right infront the reciever gets taint so it blocks the eye and it seems like the remote is not working just look into it when servicing
Posted on Nov 06, 2009
SOURCE: indoor a/c remote control will not work. How do I manually
If you lift the filter cover, on the right you will see a wiring diagram. Above the diagram and to the left , you will see a small hole that is about a fourth of an inch in diameter with a rod in the middle. Touch the rod and the unit will come on AUTO. Touch it again and the fan will reduce speed. One more time and it will go off.
Posted on Jul 13, 2011
Why wont the tv pick up any HDMI input?
Hello. CEC stands for Consumer Electronics Control. This allows you to use one remote control to operate multiple devices that are connected with the HDMI cables. Since all of the equipment worked before the power surge, it is very likely it will work again. We just need to "reset" everything.
Start by unplugging all devices from AC power and disconnecting the HDMI cables. Assuming you are using the TV remote to control everything, pug the TV back into AC Power and turn it on. Go thru all standard setup on the TV as needed (set date and time, scan for channels, etc). Turn the TV off.
Connect the first HDMI device to AC Power, connect the HDMI cable and then turn on the TV and the HDMI device. Check to see if the remote controls both devices. If it does not, go thru the Setup options on the HDMI device (you may need to use the original remote control) and see if there are any settings that apply to the HDMI CEC settings (enbable or turn them on).
Repeat this for additional HDMI devices.
By unplugging both the controlling device (TV) and the controlled device (such as a Bluray/DVD player) and then reconnecting them in the correct order, you should be able to get all devices working on the same remote again.
Sep 03, 2014 | Insignia IS-LCDTV32 32 in. Television
Tv remote wont work the lights turns on but still wont work
There are two ends to IR control; the remote itself and a receiver inside the set that is active any time the set has AC available. Testing the receiver end requires a known-working remote control but you can check to see if the remote is still sending IR signals by taking any digital camera you have on hand, turning it on as if you wanted to take a snap of something, watch the display while you aim the working end of the remote toward the camera's lens and holding down any button on the remote. If the remote is sending IR signals, you will see these as white spots, often blinking rapidly, on your camera's LCD screen.
If the remote is outputting IR, the receiver in the TV is likely dead and will require replacement.
Jun 01, 2012 | RCA Televison & Video
Hitachi AC's remote control sensor not working
Hitachi AC's are now made with "bovine ***** material" quality. we have two brand new AC's neither is working now. Remotes are not sensing at all. Hitachi is "bovine ***** matter" now.
Apr 05, 2012 | Heating & Cooling
I have a split type LG ac and I the remote control is always not working whenever I press the on button to turn on my AC. This is my 2nd remote control given by the company who installed my AC after I...
Nov 06, 2009 | Heating & Cooling
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
654 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
