Question about KitchenAid KUDS30IVBL Builtin Dishwasher
Kitchenaid kuds301xss0 4 hour delay and cancel drain lights wont go out, half lit
GodBlessU
  • 3513 Answers
SOURCE: kitchenaid normal cycle light and cancel light
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Jun 02, 2010
  • 6 Answers
SOURCE: Kitchenaid kud101tj "cancel drain" light and
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Posted on Oct 05, 2010
SOURCE: KitchenAid 24 in. KUDI01TJ will
http://www.applianceblog.com/mainforums/kitchenaid/17513-fixed-cancel-drain-light-flashing-not-working.html
Hi it's hard to diagnose from symptoms described, but try this post and fix below i am pretty sure this may be whats happening with your unit? Please read right through to the bottom....
Posted on Jun 18, 2011
Daniel S
  • 4323 Answers
SOURCE: Kitchenaid KUDI02frwh1 wont start.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
ercupa190
  • 12223 Answers
SOURCE: How do I shut off the 4 hour delay button?
see this possibles causes:
Water pre-heating
the water must be preheating, if do not doing increase the temperature water, this problem will take 1hour, causing the problem too long
The heating element can be faulty or thermostat, test it see how.The cicle can continue and goes on and NOT STOP.
Cycle not completing
timer can be defective: clean contacts, tight for loose wires, break, or burn and repair. God bless you
Posted on May 26, 2012
Water pre-heating
May 25, 2012 | KitchenAid KUDS30SXSS Builtin Dishwasher
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
KitchenAid KUDS30IVBL Builtin Dishwasher Logo
60 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
