Question about Blaupunkt Car Audio & Video
Skoda dx pin safe - Blaupunkt Car Audio & Video
Hi my the symphony radio in my skoda fabia is stuck on safe mode
hi paul unfortuntly you need a new radio the code was entered wrongly too many times even the dealer cant fix them ok
Nov 21, 2016 | Skoda Cars & Trucks
Skoda felicia 1998 steering wheel column has small gap is it safe how repair
take it to a skoda dealer or VW shop ( VW make skoda) and have them check out the problem
it could be a simple adjustment or a much more dangerous fault
Jul 02, 2016 | Skoda Cars & Trucks
Pump relay location
From the Haynes repair manual:
'access to the relays can be obtained after removing the drivers side lower facia then remove the two plate screws (one either end) and lower the plate complete with relays'. Some relays are at the rear of the engine (the second box left to the nearside suspension strut) as your looking into the engine (under a cover)
The fuel pump works off of these fuses/relays:
Pin 5 goes to fuse no. 32
Pin 10 goes to fuse no. 34
Fuses are fed from relay no. 109
Hope this helps, a diagram of the footwell is here:
http://pics2.tdiclub.com/members/MIGOLFGLSTDI/footwell.jpg
Aug 30, 2014 | 2008 Skoda Octavia 1.9
Skoda fabia 04 plate ive replaced after market stereo with the original skoda symphony one i put the code in and it works however everytime i restart the var it goes into safe mode
You may have the 'backup' supply line switched with the ACC/IGN supply line.Backup has permanent 12V supply. ACC line only have 12v after you turn the key to position 1 or ACC.
Jul 20, 2014 | Cars & Trucks
How to disconnect reversing sensors skoda fabia estate 2009 model
remove socket , press all S.W in then turn to anticlockwise , pull out when . put new one , first pull the pin out , till come out longer .then press back (adjustment ) then turn clockwise
Jun 27, 2014 | 2008 Skoda Fabia 1.2
Skoda fabia steering unlock problem
try to move steering little left / right before you try .need to put grease inside the pin of steering lock
Apr 22, 2013 | 2008 Skoda Fabia 1.4
How i can know the pin in pcm for skoda
To pin out or in check- any module- you need wiring diagrams
The best source is a local repair shop with a data base of factory
reference material, they should print for you
Be careful you don't load the circuit if your back probing a pcm
I would not do that
I would disconnect the cables & test them & assume your pcm
is okey.
Feb 02, 2013 | Skoda Octavia Cars & Trucks
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Car Audio & Video Logo
24 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
