Question about Gateway MX3215 Notebook
HOW DO I PUT ON A NEW OS?
HOW TO PUT ON A NEW OS
  • Gateway Master
  • 13,433 Answers
You need to use the the installation cd of the OS (Operating system, eg.Windows) you want to install into the computer. insert the cd and you should get a message to start from cd.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Posted on May 21, 2009
Hdd crashed , it dosent see hdd so how do I put new hdd in and install op system
Replace the hdd and place your OS disc in the drive. Boot from the OS disc and install the new system.
Mar 14, 2015 | Computers & Internet
Bootmgr missing
Place your OS system disc in the cd/dvd drive and boot from that. Follow prompts to format the Hard Drive and place a new OS on the drive.
Oct 27, 2013 | MSI MS-U135DX-1679ZA Netbook
F3-f100-003 error code what does it mean?
The new HDD apparently has no OS. what is what the msg says.
boot to Bootable media with to install a NEW OS. or boot to your Recovery Media. and let it restore to Factory.
if this does not help - then provide more info.
Jan 18, 2013 | Toshiba Satellite Computers & Internet
HOW CAN I PUT A NEW OS ON MY LAPTOP THAT I PUT A NEW HARD DRIVE IN
You can't copy the operating system from your PC to your laptop. However, you can install a new operating system which is Windows 7 64 Bit which is the same with your PC. You have to have the DVD (Windows 7 Installation Disc), drivers for your laptop, and the DVD for the programs that you want to add to your computer.
Before installing a new OS to your laptop, make sure that you have saved all the important files to an external saving device such as a USB flash drive. You have to make sure that your laptop has all the specs to run Windows 7. Please visit the link below to check the minimum requirements (system) for Windows 7.
http://windows.microsoft.com/is-IS/windows7/products/system-requirements
Hope this helps.
Nov 14, 2012 | Microsoft Windows Vista Ultimate Edition
How do i install os after installing new hdd
once u install new HDD...put the OS cd in and restart PC and keep tapping f12...and once u get message then press any key to boot from CD...and then follow on screen instruction
Feb 13, 2012 | Samsung N150 (36725723009) Netbook
Put in a new hard drive and all i get is an error what i'm i doing wrong
You need to install a OS disk (operating system disk) ie windows xp / vista / 7.
When buying a new harddrive, they are blank (No OS on them / nothing)
Place your OS into the disk drive and keep hold of power button until notebook powers off.
Turn back on your notebook while disk incerted and follow the simple instructions given to you via the OS disk
Hope this helps and pleae rate.
Mar 22, 2011 | Toshiba Satellite L455DS5976 Notebook
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
I have put the serial number once. Now it ask me to activate again but am not able to put the key again. Can I do telephone activation?
You have not activated your Operating System(OS) and OS activation period have expired assumming you are using Windows. You need to enter new serial No. in order to activate online. If your OS is genuine, you can call microsoft to get a new Serial or you can go back to the vendor where your purchase the OS.
Jun 30, 2010 | Computers & Internet
Not letting me put new os system on new hard drive?
Start from scratch. format your HDD and re install the OS via recovery disc.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
AC'97 Audio Codecs Blue screen of death on install please help me fix this problem thanks dell dimension 2350
This usually means your HD has a virus. It could be a boot virus. The best way to get rid of it is to completely reinstall your OS. When you turn on your computer put in your OS software or recovery software (if software recovery does not work you will have to put on new version of OS from another disk). After you put the disk in, restart your computer and hit Enter when the screen prompts to Boot from CD...
If this does not work, you can purchase a anti-boot virus software from your local comp store, otherwise you may need a new HD. But try reinstalling the OS from scratch, that is the best way.
Oct 03, 2009 | Dell Dimension 2350 PC Desktop
Gateway MX3215 Notebook Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
