Question about Akai PT46DL10 46" HDTV-Ready Television
Akai lamp replaced dlp lamp a red indicator light says on "lamp operation exceeds its rated lifetime" is there need to set a lifetime date to make the light go out the tv operates fine
  • 15 Answers
SOURCE: Can't reach AKAI about replacing lamp cartridge.
the bulb is not the original bulb. you need to purchase a 9 pin RS-232 connector cable and reset the lamp life counter on the bios of the tv if the picture is still fine on the TV. (make sure the cable has a male end and a female end and attach it to your computer and the data port on the back of your tv beside the pc input, there should be a male end on your computer that looks like a monitor input but backwards)
Then I downloaded the service manual from (under service manual, click on akai and then scroll to the bottom of the page where the model number of the TV appears; there in the manual they have all the codes to reset your tv, adjust all settings, do a diagnostic of your tv to find problems etc.
The cable only costs 5-10 dollars at most computer stores in your city
Hope this helps
Posted on Jul 01, 2009
0 characters
1 Points
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
Sep 29, 2014 | Akai PT46DL10 46" HDTV-Ready Television
I have replaced my DLP lamp cartridge twice and put times after installation the lamp light(red) indicated the lamp needed replacing. What could be the cause.
sounds like a mitsubishi with bad power capacitor. I will need the model number of your set in order to assist you with the problem.
Jan 11, 2010 | Projection Televisions
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Jul 20, 2009 | Zenith Z56DC1D 56" Television
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Set wont turn on
IF this is a dlp tv , the first thin you need to do is replace the lamp. J.D.W.
Jun 18, 2009 | Akai PT4298HD Rear Projection Television
its very simple small cover on back of tv remove this to replace lamp as its inside new lamp is available a just be sure to order right one check last digits on seriel number should be a J or Z that will tell you the one to order to reset lamp light push menu then enter
Feb 11, 2009 | Akai PT46DL10 46" HDTV-Ready Television
My akai dlp tv is flashing power and lamp the red lights then to the timer is also flashing green light
the back cover is not on the TV correctly. on the back cover there is a safety switch so that the lamp light is not exposed. The lamp emits radiation and UV rays. Not healthy.
Dec 23, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
133 people viewed this question
Top Akai Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Akai Projection Television Expert? Answer questions, earn points and help others
