Question about Samsung FPT5084 50 in. Plasma HDTV
Power not coming on
Television automatically turned off and cannot re start manually or via remote
2 Suggested Answers
SOURCE: automatically turns off
I have the same problem and had a samsung technician come to the house. It was the Power Board and the main board. He gave me an estimate to fix and it was $529. I'm trashing the TV. Samsung sucks.
Posted on May 22, 2009
TV will not switch on using the remote or manually on TV
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | LG 50PX1D 50 in. Plasma Television
Insignia 32" lcd will not turn on
The standby part of this set's power supply provides voltage 7-24 for the remote to work via the microprocessor and also will provide voltage for the mechanical relay if there to fire the main power supply.
Dec 06, 2012 | Insignia IS-LCDTV32 32 in. Television
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Automatically turns off
May 17, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
42PD6600A and EXT-6
I have the same problem with my 42PD6600. Spoke to the gents at Hitachi who tell me there is no automatic way to do this so you have to scroll manually to the correct source via the remote.
Mar 05, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Power, audio and video peob;em
go to menu and put the video into the right spot and check with your audio setup menu.
May 31, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
I have this problem starting today. Unfortunately, others who have fixed it have done the following.
* Unplug TV for hours and it worked
* Buying manual switch to the outlet or surge protector and switch power off that way.
It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
Samsung FPT5084 50 in. Plasma HDTV Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
