Question about Harley Davidson Lands Phones
Bike sounds like it is wheezing - Harley Davidson Lands Phones
How do I stop the wheezing sound from my Samsung refrigerator?
Check your door gasket for leaks try to identify where the sound is coming from and get back with me
Apr 03, 2017 | Cars & Trucks
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
2005 Kia Spectra wheezing sounds in a/c
Check the belt first a bad belt is very likely.
May 31, 2010 | 2005 Kia Spectra
My 60 inch Phillips Magnavox Rear Projection Tv will not turn on and there is a wheezing sound coming from inside it.
Hi
Thanks for using FixYa. Wheezing sound can be caused due to many reasons however, to start with open the back of the unit and check the power supply board for any blown capacitors. Also check the flyback as it can be some loose wires in the coil. Usually this happens when there is a vibration in the horizontal circuit, the flyback and/or coil can make this noise. The flyback can also go bad and cause this issue, opening the unit is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 28, 2010 | Televison & Video
A noise in 5th gear only on a 99 Vstar
this sounds like a bearing in the gear box on the lay shaft maybe prop the bike up on a satnd and run it up in gear to here the gear box working
ps,,,dont let it fall off the stand when its running up!
Nov 22, 2009 | 1999 Yamaha V Star Classic
My 2006 Toyota Corolla is Wheezing
without hearing it?? try another mechanic prefferably and old dinasaur like myself with experiance
Oct 23, 2009 | 2006 Toyota Corolla
My hard drive is making wheezing sounds and won't connect to mypc
Dear,
It looks like physically your disk is damaged. You have to consulte service center for data recovery. Keep hardisk either horizondally or veritically and try
Oct 13, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My transmisson makes a weezing sound when im at low speed
You sure its the transmission? Wheezing sound is usually the catylitic converter becoming plugged. Also...at 3-5K rpm you are not idling, you are reving the engine...(in that case, trans may be slipping or flairing between shifts, unless the unit is staying in one gear and just delaying shift till you reach that rpm. actual shift point should be close to 2,000rpm) I'd check the cat first.
Apr 17, 2009 | 1996 Jeep Grand Cherokee
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Lands Phones Logo
11 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
