Question about M&S Systems M & S SYSTEMS DMC1CDB Whole House CD Player for DMC1 CD Player
M&S MC 602 intercom system is making a clicking noise and flashing List and Talk and 32, 32, 30 etc on display.
Makes clicking noise and flashes, List, Talk and 32, 31,30 etc on display
2 Suggested Answers
SOURCE: MC 602 one of door bells rings intermitently.
I pulled the MC 602 from its wall case to examine wiring. Found a most unprofessional mess of wire connections. Cleaned up wiring and clipped the extra exposed shielding. Problem has not reoccurred, but time will tell it has sometimes been days between false rings.
Posted on Oct 14, 2009
No fuse flashes on the display and the fuse box makes a clicking noise
Clicking noise is a relay. Not a fuse. You will have to find which relay is bad out out.
Oct 30, 2015 | 2011 Dodge Grand Caravan
Generac troubleshooting
Your battery is dead..If the controller has a visible display your battery charger is most likely OK. Just put in a new Group 26R battery and set the time etc.
Sep 07, 2014 | Generac Guardian 20kW Model : 5875
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
Kingston flash drive when sending files,data and media displays a dialog box >> like this WRITE PROTECTED-- help me pls...
it seems that the file or the system in your flash drive error, to fix this issue try to format your flash drive. To format the drive you can follow this way
right click on my computer icon in our desktop
click manage
click disk management (in a storage tab)
right click on your detected flash drive (could be in F)
click format
make a system as fat32
list on perform a quick format
Notes: it will erase all your data on your flash drive
May 23, 2011 | Computers & Internet
Television is making clicking noise after repalceing lamp
You need to leave a lot more information than that.What is the background of replacing the lamp? Where is the clicking noise coming from? Is the lamp light flashing, etc.? My current best guess is that your ballast may be bad, but more info is always helpful in diagnosing a problem. Good luck.
Mar 25, 2011 | Mitsubishi WD-73734 73" Television
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Hi im new at this and not shure how to use this 4gb flash drive,i installed it in to the usb port and nothing came up ,can you help to tell me how you work it i have a sony pc with windows xp
Firstly, make sure you're logged in an admin account
  1. Click Start > Run
  2. Type diskmgmt.msc & press Enter
  3. If the initialisation wizard doesn't pop up automatically, scroll down the bottom half of the list to find your flash drive (starts with disk 0, disk 1 etc).
  4. Right click the unallocated space of the flash drive and click Format
  5. Follow the onscreen prompts.
If you can't see your flash drive in the list, try another USB port.
Dec 02, 2010 | Computers & Internet
M&S Systems, #MC350A, central intercom system, malfunctioning
I'm having the same problem. I think LIST means it is in LISTen mode, listening to the outside door station. Why it is doing that is unclear.
Oct 18, 2009 | Audio Players & Recorders
Oct 13, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
532 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
woodzowl307
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
