Television manuals I have an old Panasonic TV (CT27631u). Trying to determine watt draw on electrical system. How many watts does it draw?
Noggin
  • 944 Answers
SOURCE: how many watts does the tv take, anybody know?
Here's the link for the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/PVC1320.PDF Check page 39. 120vac - power on = approx 69W I wouldnt get an inverter too close to that figure, but a 200w inverter should do - just check the inverter specifications to verify if the rating is actual power output - many inverter manufacturers are a little creative with their model names etc, but the real info has to be somewhere on the box. If in doubt then the best way is to evaluate your battery system capacity and usual recharging input, and match the current drawn by an inverter to half that figure, see what power inverter size you can manage. if you buy bigger, you get more watts per dollar usually, and you may want any surplus capacity later for another item. Also running inverters up towards their maximum often will shorten their life dramatically. Hope this helps :)
Posted on Jun 27, 2007
SOURCE: Old General Electric Television
You likely have a very old set 30 or more years old? If so, search online for a "cheater cord"
Posted on Nov 08, 2008
SOURCE: No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
Posted on May 13, 2009
SOURCE: panasonic 1250 watt microwave approx 5 yr old.
something burned out, has there been a thunderstorm lately?
if you get a new one, plug it into a surge protector.
Posted on Jul 16, 2009
leethedeuce
  • 4472 Answers
SOURCE: need owner manual for 8-watt Durabrand Home
These are actually fairly easy to hook up. First off if their is 2 inputs then just go from the output of the cable box to the speaker system. Now for this system I would guess just run the audio from the cable to the home theater system. then run the video from cable box to tv. for the tv. Look if there is an audio out then plug that into stereo. If not it may not be possible to get the audio from the tv to play through the stereo. Here are a couple diagrams that may help.
http://www.4electronicwarehouse.com/connectionguides/htib.html
http://www.4electronicwarehouse.com/connectionguides/television.html
Posted on Sep 08, 2009
Amp draw on #SMA-64140A
At which voltage?
If you have 120V to it, 4,000 watts is 4000 / 120 = 33.333A.
If you have 240V, 4,000 watts is 4000 / 240 = 16.667A.
Dec 11, 2013 | King Electric Heater. 4,000-Watt Fan...
I have a Challenger 15amp breaker that is carrying my tv, lights & phone in the living room and the microwave in the kitchen. It clicked off and will not stay on when I try to reset it. What do I do?
1) First of all, you are overamping that breaker.
Look at label on each appliance for watt rating.
1200 watt microwave, 120 volts draws 10 amps.
500 watt tv, 120 volts draws 4.1 amps.
15 amp breaker rated for 80% safe maximum is 12 amps
Do not install larger breaker without increasing size of wire.
http://waterheatertimer.org/Color-codewire.html
2) Tripping breaker will not reset.
Jiggle breaker and see if there is crackling sound and check for burned smell.
Breaker might be bad. Move wire to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
3) Other problem could be electrical short, caused by Melted wire, melted outlet, bad appliance, bad surge protector
Unplug everything and see if breaker rersets.
Check each outlet to determine which are out.
Inspect each outlet and switch for appearance of burning or small of burning.
Then plug each item in one at a time, and see what is tripping breaker.
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Oct 29, 2012 | Challenger Circuit Breaker
Pls tell me the watt for tv model th-65 pv 500m
The closest thing I can find to your plasma TV is the Viera 65-in model TX-P65VT20E, which consumes 635 Watts. This should be close to the power budget for your unit.
Reference:
http://panasonic.net/avc/viera/eu2010/product/vt20_plasma_spec.html
Sep 13, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
Hype on the part of the maufacturer's published specs.
http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
Look at the Power Comsumption spec on page 22. "90 watts"
According to this post, 45 watts...
http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
To say it pushes 1000 watts is dishonest and preys on the gullible.
Apr 10, 2011 | Panasonic Audio Players & Recorders
Drawing current but not producing any heat.
I am assuming this is an electric wall mount heater, if the unit is drawing current then it should relate to heat as 3.41 btu is = 1 watt.
take the voltage reading and the amp draw and mutiply them to determine the wattage eg; 240 volts x 20.8 amps = 5000 watts = 17,050 btu. if the unit is fan assited and you are drawing 1 to 2 amps this would indicate the fan is runnning without the heat element being energized hope this helps
Nov 04, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
Using too much electicity!
We have been checking our electricity units
Not sure how you are checking but your microwave would blow fuses or trip a breaker if it was drawing more than it did since they are only ~ 50% efficient (any of them) which means a 1000 watt unit is pushing the limits of normal household circuits anyhow.
I bought two Kill-A-Watt power monitors for our two households and we are all happy with their convenience and the ability to quickly check anything that plugs into a standard US outlet and they are plenty accurate enough for us heathens.
Take a look:
I didn't price-shop too much but ours came to only $14 each plus shipping of $10 US.
Dec 18, 2008 | Panasonic NN-T888S Convection/Microwave...
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
How many watts does the tv take, anybody know?
Jun 27, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Televison & Video Logo
392 people viewed this question
Top Televison & Video Experts
Electro Med Services...
