Question about Zyxel P320W 802.11G Wireless Firewall Router
Ps3 nat failed
I have open all recomended ps3 ports on my zyxel but my nat dosent work on my ps3
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Mar 06, 2011 | Zyxel P660HW-D1 Router
I whant open in ps3
I take it that you want to change NAT type in your PS3. To open NAT type you first need to get port numbers from PS3 people. Once you get the ports check what the IP add on the PS3 is.Once you have this information login to the router interface and punch in the port numbers and the IP add and your NAT type should be open.
Hope this helped.
Jan 23, 2011 | LanTech (HR-114 II) Router
The NAT is on 3 and it needs to be 2 for the PS3 to work online properly. i have a Zyxel_41C.
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 14, 2011 | Zyxel P660HW-D1 Router
Hi there! i have a zyxel ph660-f1z and since it doesnt suport dmz i get nat type moderate on my ps3 so it gives a lot of trouble.... i have tried port fordwarding,upnp,default server but nothing seems to...
Sometimes not just the dmz or port configurations cause your nat settings to be other than open, you may not have good internet connection, the better it is the more you will open. Most routers are open by default, and those others need to be forwarded(like you wrote) with the upnp open and specific ports for xbox/ps3 servers opened. You seem to know a little already, maybe time to get a new router?,I recently upgraded myself due to problems with configuration.
Dec 15, 2010 | Zyxel P660HW-D1 Router
NAT TYPE 3 it was restrict and now open but i still can not play xbox360 and ps3 how do i fix this kindly please show me.... thanks,
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jul 17, 2010 | Zyxel P660HW-D1 Router
Hi, how can i get nat open on my ps3 whit my zyxlel router
Use port forwarding to sort out ya problem, find you router, and it will show you what to do.
www.devicemanuals.com/guide/.../ZyXEL/ZyXEL-P-660HW-D1-3-40-User-Guide-TkRjNU9EUT.html - 21 hours ago
User Guide above.
Mar 30, 2010 | Zyxel P660HW-D1 Router
I can not connect to people on my ps3 because my NAT is on strict how do i change it?
disable the firewall in the router, enable UPNP, in the router open up the following port numbers for an IP address and assign that IP manually in ur PS3.
TCP:80,443,5223, 10070-10080
UDP:3478, 3479,3658, 10070
Jan 10, 2010 | Zyxel Prestige 660HW Wireless Router...
I have a Zyxel P-660r-d1 modem and I connect to it with my ps3. But I currently have a NAT type 3, and I have some problems connecting with friends online. How do I change it to NAT type 2?
i will repost my guide for opening nat and firewall on a zyxel ...
it will help for sure ...
you can't just say nat is now OPEN :)
let's say you have a pc with IP of 192.168.1.33
you are running a emule (hehe) on that PC
you want to use port 12345 for your emule
this is what you need to do:
1. go to webinterface of your router (usually http://192.168.1.1)
2. go to menu network/nat/port forwarding
3.go to service->user define
4. in new window click "active", name it emule, start port 12345, end port 12345, server ip 192.168.1.33
5. click ok, apply, whatever and go to menu security/firewall/rules
6. choose packet direction wan to wan/router
7. click on ADD
8.change following fields: destination address - change to single addressand change 0.0.0.0 to 192.168.1.33 and click on add, then close to itsays ANY, mark it and click on remove
9. on same page under services click on edit customized services
10. choose number 1 or 5 or whatever :)
11. service name: emule rule, service type TCP/UDP, type single, port 12345
12. click on apply
13. go to menu maintenance/tools/restart
14.just in case restart the box and your zyxel is now accepting incomingconnections on port 12345 and forwarding them to 192.168.1.33 (your pc)...
i hope i helped
cheers
-tomba
Jul 01, 2009 | Zyxel Prestige 660R Router (P660R)
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Zyxel P320W 802.11G Wireless Firewall Router Logo
639 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
